Configure FTD 6.7.0 for site to site connection to remote FMC 7.0.1
Cisco_OST
I have a stand alone FTD that is remote with its only connection to the DC is via Site to Site VPN on the "outside" interface. I read where the version we are running supports using the data port as the management port, but I can not find any detail documentation on how to configure the FTD to support that function.
Thanks in advance.
Francesco Molino
 here is the documentation showing how to change the FMC access from management to data interface:
https://www.cisco.com/c/en/us/td/docs/security/firepower/misc/fmc-ftd-mgmt-nw/fmc-ftd-mgmt-nw.html#Cisco_Task.dita_0cbd837e-6a80-4e05-8734-7a73bcb2c850
if you have any question let me know.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Thank you for your response, I have another question. What about on the FTD does that need to change as well?
If you change the interface used to connect the FTD with FMC, a change has to happen on the FTD as well.
The doc I shared is showing you all steps (including configuration).
Francesco
alirafaleiro
This document describes how to configure a Route-based Site to Site VPN tunnel on a Firepower Threat Defense (FTD) managed by a Firepower Management Center (FMC).
https://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/216276-configure-route-based-site-to-site-vpn-t.html
