Configuring a 2960 for TACACS auth for SSH and radius for dot1x + MAB
kyle311
Can anyone help me out with this.  I've got Switches setup in ISE to use TACACS to authenticate the logins.  I'm looking to setup DOT1X on the ports, along with MAB.  I have the config in ISE set but i'm trying to determine exactly how to setup the swithes base raidius piece along with the switchports, without messing up TACACS.  Am i overthinking this?
nict
Hi @kyle311
I think you might benefit from looking into this article: 802.1X Switch Configuration Summarized
kyle311
is it just:
radius-server host (ip addresse) key (key)
and then"
int gix/y/z
switchport mode access
switchport access vlan x
authentication port-control auto
dot1x pae authenticator
dot1x timeout tx-period 10
dot1x timeout uppp-timeout 10
nict
Hi @kyle311
Thank you much that was EXACTLY what I needed!
