Configuring static PAT's using port ranges on ASA's
Sami Abunasser
I am in the process of replacing all of our checkpoint firewalls with Cisco ASA's. I am curently running into the following problem with configuring static NATs and PATs.
At some of our locations, the external IP's are mapped to internal IP's based on port ranges, and I can't find a way to replicate that on the ASA. Here's an example:
External NAT     External Port                    Internal Host
1.1.1.20               UDP 9000                        10.10.10.1
1.1.1.20               UDP 50000-65500             10.10.10.2
1.1.1.20               ANY                                10.10.10.3
I could find any way of configuring a static NAT that using the port range (50000-65500), and i'm not about to write 15000 static NAT statements.
Does anyone know how you can use the port range in the static NAT?
Sami
5 Replies 5
Anu M Chacko
Hi Sami,
Unfortunately, you cannot configure a range of ports in Static NAT. You will need to configure a one-to-one static NAT for it and an access-list to open ports in the ACL.
static (in,out) x.x.x.x y.y.y.y netmask 255.255.255.255
access-list out permit ip any host x.x.x.x range 50000 65500
where x.x.x.x is a public IP given to you by the ISP.
Hope this helps!
Anu
P.S. Please mark the question as resolved if it has been answered. Do rate helpful posts.
Anu,
Thanks for the response, I kind of knew that we couldn't do that, since I couldn't find any way of actually configuring it. I can't use an ACL to allow the ports, due to the problem that the external IP is the same, and the internal IP changes based on the port that is used, so it's more of a static PAT.
But thanks for the input...
- Sami
Jay Johnston
This can be accomplished easily using the NAT syntax of ASA version 8.3 or greater:
object network obj-10.10.10.1
   host 10.10.10.1
object network obj-10.10.10.2
   host 10.10.10.2
object network obj-10.10.10.3
   host 10.10.10.3
object network obj-1.1.1.20
   host 1.1.1.20
object service obj-serviceUDP9000
    service udp source eq 9000
object service obj-serviceUDP50000-65500
   service udp source range 50000 65500
nat (inside,outside) source static obj-10.10.10.1 obj-1.1.1.20 service obj-serviceUDP9000 obj-serviceUDP9000
nat (inside,outside) source static obj-10.10.10.2 obj-1.1.1.20 service obj-serviceUDP50000-65500 obj-serviceUDP50000-65500
nat (inside,outside) source static obj-10.10.10.3 obj-1.1.1.20
ASA(config)# show nat detail
4 (inside) to (outside) source static obj-10.10.10.1 obj-1.1.1.20 service obj-serviceUDP9000 obj-serviceUDP9000
    translate_hits = 0, untranslate_hits = 0
    Source - Origin: 10.10.10.1/32, Translated: 1.1.1.20/32
    Service - Origin: udp source eq 9000 , Translated: udp source eq 9000
5 (inside) to (outside) source static obj-10.10.10.2 obj-1.1.1.20 service obj-serviceUDP50000-65500 obj-serviceUDP50000-65500
    Source - Origin: 10.10.10.2/32, Translated: 1.1.1.20/32
    Service - Origin: udp source range 50000 65500 , Translated: udp source range 50000 65500
6 (inside) to (outside) source static obj-10.10.10.3 obj-1.1.1.20
    Source - Origin: 10.10.10.3/32, Translated: 1.1.1.20/32
ASA# packet-tracer input outside udp 4.4.4.4 48483 1.1.1.20 9000
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
Additional Information:
NAT divert to egress interface inside
Untranslate 1.1.1.20/9000 to 10.10.10.1/9000
ASA# packet-tracer input outside udp 4.4.4.4 48483 1.1.1.20 50032
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
Untranslate 1.1.1.20/50032 to 10.10.10.2/50032
Jay,
Thank you for the response, i really haven't had any exposure to 8.3 yet, but I have enough memory in the ASA to upgrade. I will give it a test and see if that works out, it does seems like it should.
Sami
Sami,
     Yep, it should work with no problems. For more information about version 8.3 and the upgrade process, see this page that David wrote:
ASA 8.3 Upgrade - What You Need to Know
https://supportforums.cisco.com/docs/DOC-12690
Also linked on that page are some introduction to 8.3 NAT videos that we've done.
- Jay
