Connection/Performance Problems after 6.3 to 7.2 upgrade
tunemore1
Here is config on PIX515E wiht 7.2.2.
[The old config with 6.3.4 worked fine.]
After upgrade, access from outside stopped working. Here is the config with 2.2.
Any help? Thanks,
fw# sh run
: Saved
PIX Version 7.2(2)
hostname fw
names
dns-guard
interface Ethernet0
nameif outside
security-level 0
ip address 10.10.10.1 255.255.255.248
interface Ethernet1
nameif inside
security-level 100
ip address 172.17.17.1 255.255.248.0
interface Ethernet2
shutdown
nameif intf2
security-level 4
no ip address
ftp mode passive
access-list 111 extended permit tcp any host 10.10.10.1 eq 7700 log
access-list 111 extended permit udp any host 10.10.10.1 eq 6600 log
icmp unreachable rate-limit 1 burst-size 1
nat-control
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp 10.10.10.1 7700 172.17.2.111 7700 netmask 255.255.255.255
static (inside,outside) udp 10.10.10.1 6600 172.17.2.222 6600 netmask 255.255.255.255
access-group 111 in interface outside
route outside 0.0.0.0 0.0.0.0 10.10.10.254 1
route inside 172.17.0.0 255.255.0.0 172.17.17.254 1
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect http
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect sip
inspect xdmcp
service-policy global_policy global
fw#
jgervia_2
Not sure if this is the issue or not, but a couple of things:
1) Your default route next hop is not on the same network as your firewall.
Your netmask on the outside interface (255.255.255.248) means that the only IP addresses that it can reach are 10.10.10.1 - 10.10.10.6, with 10.10.10.7 being the broadcast. However your default route
Says that the next hop is 10.10.10.254, which wouldn't be on the same network, unless you change the netmask.
Similarly, I'd check netmask on the inside interface to make sure you really want a 255.255.248.0 (8 Class Cs) local to that firewall interface.
Also - I'd check the log for any suspicious log entries - are you getting anything indicating no route
--Jason
Please rate this message if it helps solve some or all of your issue.
It was typo, subnet mask should be 255.255.255.0 for outside interface.
Jason, thanks for reply. Do you have any idea?
Everything was ok after downgraded back to 6.3.4.
