CSPM 3.0 and PIX 515 problem
pambosch
I'm trying to use CSPM 3.0 for managing a PIX 515 with three interfaces and 4 VPNs terminated on it. I have already configured the PIX with CLI and works fine, but I just acquired CSPM3.0 and want to use it for management. The problem is that after I succesfuly created my exact network topology and configured all policy rules, the command generation feature does not reflect the actual policy rules, even if I saved and updated the database. When I preview the commands generated (before publishing them on the PIX), I notice that these commands do not cover all policy rules that I configured. For example, I have a rule permiting all IP traffic from inside to outside, but the command generation shows an access list which denies ALL outbound traffic. This is just one example....there are many more.
any help please?
Thank you in advance.
Pambos
bhose
I have not used CPSM version 3 but I have done a lot of work with 2.3.
I found that that I had to spend a lot of time making sure that the network topology was correct in order for the correct rules to be generated. There were a few strange issues that I had with rules not being generated and most of the time I just had to play around with the topology until I had it right.
With your config do you get any errors/warnings when you do a save and update ? I found this fairly helpful.
While CSPM is a good product for managing multiple firewalls I find its adds too much management overhead to be valuable is a single firewall environment. Just my opinion
Regards Brett
