Cut-Through and Direct ASA HTTP Authentication
Ahmad Khalifa
Level 3
Level 3
hi
i am trying to test the ASA authentication in my LAB before implementing in real production system amd its not working
my lab is to having HTTP server set in the inside network (IIS) and outside network , the IIS server is Static NAT to the out side , ACL to allow HTTP to the sever from Outside network AAA rule is applied to authenticate the Connection but no request for authentication when attemp to access the web server .
any idea ?
here is output of configuration
: Saved
ASA Version 8.4(2)
hostname IISFW
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1
 nameif IIS
 security-level 100
 ip address 10.1.1.1 255.255.255.0
interface GigabitEthernet2
 nameif outside
 security-level 0
 ip address 192.168.100.1 255.255.255.0
interface GigabitEthernet3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet5
 shutdown
 no nameif
 no security-level
 no ip address
ftp mode passive
clock timezone AST 3
object network IIS
 host 10.1.1.5
object network IIS_icmp
 host 10.1.1.5
object network IIS_REMOTE
 host 10.1.1.5
object-group service DM_INLINE_SERVICE_1
 service-object icmp
 service-object tcp destination eq www
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_1 any object IIS
access-list IIS extended permit tcp any any
pager lines 24
logging enable
logging asdm informational
mtu IIS 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-714.bin
no asdm history enable
arp timeout 14400
object network IIS
 nat (IIS,outside) static 192.168.100.5
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server ASA protocol radius
aaa-server ASA (IIS) host 10.1.1.5
 key *****
 radius-common-pw *****
user-identity default-domain LOCAL
aaa authentication enable console LOCAL
aaa authentication serial console LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
aaa authentication match IIS IIS ASA
aaa authentication listener http IIS port www redirect
http server enable
http 0.0.0.0 0.0.0.0 IIS
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username admin password eY/fQXw7Ure8Qrz7 encrypted privilege 15
username cisco password 3USUcOPFUiMCO4Jk encrypted privilege 15
username http password 6OvUPoxhQgt3X6on encrypted
username http attributes
 service-type remote-access
class-map global-class
 match default-inspection-traffic
policy-map global-policy
 class global-class
  inspect http
  inspect icmp
service-policy global-policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
crashinfo save disable
Cryptochecksum:96123be00fc2e4d399ddc0b063bde939
: end
Rishabh Seth
Level 10
Level 10
Try applying aaa authentication on the ingress interface for the traffic.
From your configuration i think the ingress interface would be outside interface.
try changing aaa config to:
aaa authentication match IIS outside ASA
Do share your findings.
R.Seth
Don't forget to mark the answer as correct if it helps in resolving your query!!!
Rishabh Seth
Level 10
Level 10
R.Seth
hi
thanks a lot while i am waiting for any reply i realize the issue with the ingress interface but thanks very much , another thing there is no timeout for this authentication i mean once you enter the credential for the access process its not asking you each time you visit the site  without saving the login information into the browser that users use.
any idea for this ?
BR
