deadline approaching need help with PIX501e
cworsham80
I am able from an external pc, successfully connect and authenticate locally with my PIX using the Cisco VPN Client software, shows that everything is connected. I am assigned a local IP address of 192.168.0.130 which is the first in my vpn pool. the internal ip of the pix is 192.168.0.1, I also have a pc behind the firewall with an ip of 192.168.0.40, first in its pool. I cannot, however, ping from 192.168.0.130 to 192.168.0.40 nor 192.168.0.1. I can however ping in a single hop the outside IP address of the PIX. From behind the pix i can only ping the inside ip but not outside or to the vpn'd machine. please help.
10 Replies 10
ajagadee
Chris,
I thought I answered this in the other thread, I guess it did not get posted.
Anyways, it is my understanding the above set up will not work because the VPN Client Local subnet is the same as the remote subnet that you are trying to access through the IPSEC Tunnel. If you look at the routing table on the OS, the subnet shows as a local route and the packets will not be sent across the tunnel.
Arul
thnx, I reset the PIX to factory defaults and started over on this thing changed my inside addressing to 192.168.2.0 255.255.255.0 i have put back in all the line items i could make sense of. here's what i have so far, i can connect to the vpn, authenticate locally but unable to flow traffic from a pc behind the pix to/from a pc that vpns in. i really need to get this thing up today if at all possible. right now its starting to look like its gonna be a long day
cworsham80
Result of firewall command: "show run"
: Saved
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname catalystpix
domain-name catalystdemo.com
clock timezone EST -5
clock summer-time EDT recurring
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol pptp 47
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
object-group service VPN tcp-udp
port-object eq pim-auto-rp
port-object eq echo
port-object eq kerberos
port-object eq discard
port-object eq sunrpc
port-object eq domain
port-object eq tacacs
port-object eq talk
object-group network VPN1
description IP Addresses of VPN user
network-object 192.168.2.0 255.255.255.0
object-group network Everyone
access-list inside_outbound_nat0_acl permit ip any 192.168.2.0 255.255.255.0
access-list outside_cryptomap_dyn_20 permit ip any 192.168.2.0 255.255.255.0
access-list 101 permit tcp any host 206.248.243.98 eq pptp
access-list 101 permit tcp any host 206.248.243.98 eq netbios-ssn
access-list 101 permit udp any host 206.248.243.98 eq netbios-ns
access-list 101 permit udp any host 206.248.243.98 eq netbios-dgm
access-list 101 permit gre any host 206.248.243.98
access-list 101 permit tcp any eq www any eq www
access-list outside_access_in permit icmp any any echo-reply
access-list outside_access_in permit icmp any any unreachable
access-list outside_access_in permit icmp any any time-exceeded
access-list outside_cryptomap_dyn_40 permit ip any 192.168.2.0 255.255.255.0
pager lines 24
logging timestamp
mtu outside 1500
mtu inside 1500
ip address outside 206.248.243.98 255.255.255.0
ip address inside 192.168.2.1 255.255.255.0
ip verify reverse-path interface outside
ip audit info action alarm
ip audit attack action alarm
ip local pool vpn 192.168.2.100-192.168.2.149
pdm location 192.168.2.0 255.255.255.0 outside
pdm location 192.168.2.0 255.255.255.0 inside
pdm location 206.248.243.0 255.255.255.0 outside
pdm location 206.248.243.0 255.255.255.0 inside
pdm location 206.145.84.0 255.255.255.0 inside
pdm location 206.145.84.0 255.255.255.0 outside
pdm location 216.12.23.0 255.255.255.0 outside
pdm location 216.12.23.0 255.255.255.0 inside
pdm group VPN1 outside
pdm group Everyone outside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 206.248.243.97 1
cworsham80
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa-server VPN protocol tacacs+
http server enable
http 192.168.2.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto dynamic-map outside_dyn_map 40 match address outside_cryptomap_dyn_40
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map client authentication LOCAL
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup demo address-pool vpn
vpngroup demo dns-server 192.168.2.1 216.12.23.231
vpngroup demo default-domain catalystdemo.com
vpngroup demo idle-time 1800
vpngroup demo password ********
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group demo ppp authentication mschap
vpdn group demo ppp encryption mppe 40
vpdn group demo client configuration dns 192.168.0.1 216.12.23.231
vpdn group demo client accounting VPN
vpdn group demo client authentication local
vpdn group demp pptp echo 60
vpdn username demo password *********
vpdn enable outside
vpdn enable inside
dhcpd address 192.168.2.50-192.168.2.99 inside
dhcpd dns 216.12.23.231 209.145.84.131
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
username demo password XjFBA5DVYjFLLcDW encrypted privilege 15
terminal width 80
Cryptochecksum:308a765936f2fbee500769cd247dd333
: end
Chris,
Enable this command on the pix"
isakmp nat-traversal
and try testing again. If still have issues, do post the output of "show crypto isakmp sa" and "show crypto ipsec sa" along with the IP Address that you are trying ping.
Arul
*Pls rate if it helps*
same thing. from outside coming into the pix i get assigned ip 192.168.2.100. Behind the firewall I have a PC with addy 192.168.2.60. I cannot ping in either direction one to another. from .2.60 i can ping .2.1 from 2.100 i cannot. I havea attached the results from the commands as well as a recent show run
Hi Chris,
Is there any reason why you are using RA vpn pool network the same as your inside LAN network?
I would first start suggesting to use different vpn POOL network from that of your inside net 192.168.2.0/24, even if you break down it just opens up for problems, I have seen issues using same network inside and RA network in remote access vpns, it is just cumbersome to troubleshoot and most of the time it just don't work.
from 2.60 you can ping 2.1 fw inside interface thats normal, from 2.100 to ping 2.1 you need management-access inside statement but to be honest you have nat-t enabled if you cannot reach 2.60 either 2.60 has a firewall turned of its own or this may not work.
Probably u would spend less time with a clean RA vpn pool and move on with proper RA config.
1- Create new network for RA demo tunnel , pick different net something like 10.20.20.0/24 and create new pool
b- update your nat exempt access list to allow the traffic from new vpn pool network to your LAN networks 192.168.2.0/24
Try above suggestion and post results
Rgds
Jorge
Jorge Rodriguez
Chris,
I dont see anything wrong with the VPN Configuration on the Pix that will block traffic to the 192.168.2.x/24 subnet.
Couple of quick questions:
1. On your vpn client settings for the vpngroup demo, under the tab "Transport", can you make sure that you checked "Enable IPSEC Transparent Tunneling" enabled and IPSEC over UDP option is checked.
2. Also, how are you connecting to the Pix. Are you behind another Pix firewall. If the local PIX is doing PAT/NAT. One option is to configure
fixup protocol esp-ike
Please see the PIX 6.3(x) release notes for more info. as below,
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/63rnotes/pixrn63.htm
#67762
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/df.htm#wp1067
379
#65230
Please note that if you use this "fixup protocol esp-ike" command on the local PIX, then this PIX can only pass a single vpn tunnel outbound and you cannot configure any vpn on this local router at all. For example, you cannot configure the command,
Arul
changed my vpn pool to a 10.10.10.x and that seemed to fix it. thanks to all for your help
Glad my suggestion worked for you, please rate post as resolved, so that others with similar issues can reference from.
Bst Regads
Jorge
Jorge Rodriguez
