Default gateway for both MGMT and Outside interface
WiLL-I-Am
If I have some static routes on my ASA like this
route management 0.0.0.0 0.0.0.0 x.x.x.x
route outside 0.0.0.0 0.0.0.0 x.x.x.x
and say I don't have no NAT-ing in place, is it possible that some traffic coming from the inside interface choose to go out of management interface?
@WiLL-I-Am
There are 2 routing tables, management and data routing table. The management routing table is for traffic originating from the ASA and the data routing table is for traffic through the ASA.
I assume you've defined "management-only" under the management interface? In which case you confirm it's routing table using "show route management-only".
Traffic from inside interface will only be sent via the data routing table, not via the management routing table.
balaji.bandi
It should your default route to outside - best to confrime  what version of ASA code you are running ?
BB
markus.bock
You can do policy based routing to regulate the traffic to the interface you want
@WiLL-I-Am
