Deny TCP (no connection)-ASA
elite2010
Level 3
Level 3
What does it means ?
Is there any issue
6 Apr 30 2017 13:51:12 106015 1.1.1.1 443 2.2.2.2 64274 Deny TCP (no connection) from 1.1.1.1/443 to 2.2.2.2/64274 flags ACK  on interface Outside
6 Apr 30 2017 13:59:19 106015 1.1.1.1 443 2.2.2.2 21005 Deny TCP (no connection) from 1.1.1.1/443 to 2.2.2.2/21005 flags PSH ACK  on interface Outside
6 Apr 30 2017 13:59:15 106015 10.0.10.247 63645 1.1.1.1 443 Deny TCP (no connection) from 10.0.10.247/63645 to 1.1.1.1/443 flags RST  on interface Inside
6 Apr 30 2017 13:59:15 106015 1.1.1.1 443 2.2.2.2 63645 Deny TCP (no connection) from 1.1.1.1/443 to 2.2.2.2/63645 flags PSH ACK  on interface Outside
Where is 2.2.2.2  my public ip
10.0.10.247 is my local ip address
1.1.1.1 outside ip address
Asa in active satandby mode
Philip D'Ath
Not uncommon.  It means you received a packet for a connection that does not exist or in a state that is not valid.
Is there some reason ,something need to be checked ?
Unless there is a considerable quantity of them there is nothing to check.  It is a fairly normal thing to see.
