08-16-2022 12:40 PM
I am trying to get a solid answer to see if the FPR1010-ASA-K9 comes with a power adapter,FPR1K-DT-PWR-AC, which looking at different vendors does not specify that is does. But it seems the like ~$400 on a power adapter that should be included in the package seems extremely unreasonable.
Does anyone have any issues with this?
08-16-2022 01:01 PM
it does, look at package contents section here
08-16-2022 01:03 PM
Yes all the firewalls i have purchased do.
08-16-2022 01:21 PM
Interesting. So it seems vendors are being tricky then when showing the sales price as much lower. That page shows the following that there is the base power adapter and a spare adapter with an "=" at the end. It seems FPR1K-DT-PWR-AC is not listed in the price of purchase until check out...
FPR1K-DT-PWR-AC | Cisco Firepower 1010 150-W power supply |
FPR1K-DT-PWR-AC= | Cisco Firepower 1010 150-W power supply (spare) |
08-16-2022 07:30 PM
Vendors are not being tricked, when you add the this firewall to Cisco commerce, the first option is to select power supply and power cable, both are $0 cost.
08-16-2022 11:00 PM
When you see "=" at the end, that part is used for RMA requests as a spare.
Rgards,
Chakshu
Do rate helpful posts!
