Does the base FPR1010-ASA-K9 come with a power adapter?
allenzhao
I am trying to get a solid answer to see if the FPR1010-ASA-K9 comes with a power adapter,FPR1K-DT-PWR-AC, which looking at different vendors does not specify that is does. But it seems the like ~$400 on a power adapter that should be included in the package seems extremely unreasonable.
Does anyone have any issues with this?
5 Replies 5
ammahend
Yes all the firewalls i have purchased do.
Interesting. So it seems vendors are being tricky then when showing the sales price as much lower. That page shows the following that there is the base power adapter and a spare adapter with an "=" at the end.  It seems FPR1K-DT-PWR-AC is not listed in the price of purchase until check out...
FPR1K-DT-PWR-AC
Cisco Firepower 1010 150-W power supply
FPR1K-DT-PWR-AC=
Cisco Firepower 1010 150-W power supply (spare)
Vendors are not being tricked, when you add the this firewall to Cisco commerce, the first option is to select power supply and power cable, both are $0 cost.
-hope this helps-
When you see "=" at the end, that part is used for RMA requests as a spare.
Rgards,
Chakshu
Do rate helpful posts!
