Dynamic routing failover using 5515x
timwall01
I have a problem where I need BGP to failover between failover pair ASA5515 and Azure clould.
The Azure cloud uses virtual dual routers and uses a script for the BGP setup which is limited.
The dual Azure routers are not failover capable
The ASA's do not allow for secondary ip addresses on interfaces.
If anyone has come across this issue, if you could let me know how you resolved it
nspasov
Have you looked at "Interface Zones" ?
http://www.cisco.com/c/en/us/td/docs/security/asa/asa93/configuration/general/asa-general-cli/interface-zones.html#65622
Thank you for rating helpful posts!
Is this still possible if the BGP sessions are terminating on the ASA'S and not via devices behind the firewall
