Enable ICMP to ping INSIDE to INSIDE interface
Rahul Kapadia
Hello experts,
I have an issue with ping in my LAN network, I am unable to ping my LAN network from firewall to system and system to system
access-list VLAN100_IN extended permit tcp any any eq www
access-list VLAN100_IN extended permit tcp any any eq https
access-list VLAN100_IN extended permit udp any any eq domain
access-list VLAN100_IN extended permit udp any any eq ntp
access-list VLAN100_IN extended permit icmp any any echo-reply
access-list VLAN100_IN extended permit icmp any any time-exceeded
access-list VLAN100_IN extended permit icmp any any timestamp-reply
access-list VLAN100_IN extended permit icmp any any unreachable
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect NetBIOS
inspect tftp
inspect icmp
inspect icmp error
@Rahul Kapadia When you say system to system, is this traffic within the same VLAN? If so this traffic would never be sent to the ASA.
Can you provide the full configuration of the ASA and the switch? And indicate what you've pinged and from where.
