Error Routing protocol - EIGRP between Cisco ASA with Switch 4506
quycisco123
Visitor
Dear Cisco Team,
I have problem when I configed EIGRP between cisco ASA 5510 with core switch 4506. This is below error
*Nov  4 05:08:09.898: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.16.10.20 (GigabitEthernet2/42) is up: new adjacency
*Nov  4 05:09:29.409: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.16.10.20 (GigabitEthernet2/42) is down: retry limit exceeded
*Nov  4 05:09:29.499: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.16.10.20 (GigabitEthernet2/42) is up: new adjacency
*Nov  4 05:10:35.609: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.16.10.18 (GigabitEthernet2/42) is down: holding time expired
*Nov  4 05:10:49.009: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.16.10.20 (GigabitEthernet2/42) is down: retry limit exceeded
*Nov  4 05:10:53.230: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.16.10.20 (GigabitEthernet2/42) is up: new adjacency
quang huy2004: *Nov  4 05:08:09.898: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.16.10.20 (GigabitEthernet2/42) is up: new adjacency
the tech Spec
ASA,  IOS : 8.0.2
4506, License IP Base; OS: Unisal 15 M.2
I checked between ASA with Router ok; but between ASA with 4506 error
Can you help me ?
Julio Carvajal
This logs means that the hold time expired so the hello packets are not being received, usually means multicast packets are missed-224.0.0.10)
I would recommend you to try another cable because this ussualy is a phisical or congestion issue.
Can you try that and let us know the result, also if that does not help can you send us the following outputs:
-Show ip EIGPR neighbors
-Debug EIGRP packet hello
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Julio Carvajal
Julio
Julio Carvajal
