error running script 000_start/111_FS_integrity_check.sh ///VM sensors upgrade
sholloway11
I am attempting to upgrade my VM sensors from 5.2  to 5.3.0 however I am getting the below error message on the DC.
Can anyone assist.
Aastha Bhardwaj
cd /var/log/sf/Sourcefire_3D_Defense_Center_Upgrade-5.3.0
grep ERROR FS_Check.log
Check the errors where exactly its failing .
Aastha Bhardwaj
Rate if that helps!!!
Ok..thanks,
Can this Filesystem integrity check be skip during the installation?
In most cases it is safe to skip it , but I would recommend you to open up a TAC case just to be sure .
Aastha Bhardwaj
