FDM management access issues
shepyard1980
Community Member
Cisco Firepower 1120 NGFW
FXOS: 2.10(1.75)
FTD:   7.0.1-84
Managed by FDM only
I cannot access FDM web interface or SSH on the physical management1/1 interface. I can only manage it through the data interfaces which is fine but I want to setup up HA and be able to access the standby firewall. I do not understand how the virtual management interface (management0) works I give it an IP address but no matter what I do I cannot access it on HTTPS or SSH.
Any help would be much appreciated.
6 Replies 6
If you can access via data ( in same time config as mgmt interface) then why yoh want to access via physical mgmt interface?
MHM
shepyard1980
Community Member
I want to be able to manage the standby firewall when I have HA setup, I can't access the standby firewall on the data interfaces
Ok
Try connect your PC to physical mgmt interface
Make PC NIC using dhcp not manual IP
Then try https using IP
192.168.45.45
Hope you sucess friend
MHM
shepyard1980
Community Member
No the management1/1 interface is default set to get an ip address from DHCP which I don't have to test with, if I give it a static ip address I cannot access the FDM web interface if I am on the same subnet as stated.
MHM
shepyard1980
Community Member
I'm afraid you are wrong my friend,
 https://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/fp1100/firepower-1100-gsg/ftd-fmc.html
  • By default, the Management 1/1 interface is enabled and configured as a DHCP client. If your network does not include a DHCP server, you can set the Management interface to use a static IP address during initial setup at the console port.
I cannot believe how confusing it is to just manage this device, I just need to be able to manage a standby firewall when it is part of a HA setup!
