FDM VPN site-to-site route FTD to remote LAN
webmike10
I have setup a VPN site to site between 2 firewall.
On my site Y, public IP 210.666.111.7 with 1 local LAN (10.145.49.0/24) <--config is below
On my site Z, public IP 216.55.11.82 with 2 local LAN (10.83.132.0/24 and 10.83.138.0/24)
I am trying to route site Y LAN subnet to reach a server at site Z that has a server IP of 10.83.132.40.
     At site Z I can reach site Y, local LAN (10.145.49.0/24).
At site Y I can not reach both of the site Z local LAN (10.83.132.0/24 and 10.83.138.0/24); to be able to establish a connection to create identity realm using AD directory service.
Tunnel is connected and working. Just missing, how to know to take the VPN connection at Site Y to connect to Site Z LAN (10.83.132.0/24 and 10.83.138.0/24)
site Y is using Firepower Device Manager and its config is :  [IP Addresses do not identify the actual ones used  ]
Any idea of how I must create my route.. NAT..OR Access List; whichever is required?
 : Hardware:   FPR-2110, 6843 MB RAM, CPU MIPS 1200 MHz, 1 CPU (6 cores)
NGFW Version 6.2.3
hostname firepower
interface Ethernet1/1
 nameif outside
 cts manual
  propagate sgt preserve-untag
  policy static sgt disabled trusted
 security-level 0
 ip address 210.666.111.7 255.255.255.252
interface Ethernet1/2
 nameif inside
 cts manual
 security-level 0
 ip address 10.145.49.3 255.255.255.0
interface Ethernet1/3
 shutdown
 no nameif
 no security-level
 no ip address
interface Management1/1
 management-only
 nameif diagnostic
 cts manual
 security-level 0
 no ip address
ftp mode passive
ngips conn-match vlan-id
object network USinternetAddresses
 subnet 216.55.11.0 255.255.255.0
object network US_Outside_FirePower_IP
 host 216.55.11.82
object network US_Vlan_600
 subnet 10.83.138.0 255.255.255.0
object network any-ipv4
 subnet 0.0.0.0 0.0.0.0
object network any-ipv6
 subnet ::/0
object network default_inside_route
 host 10.145.49.1
object network 10.145_16
 subnet 10.145.0.0 255.255.0.0
object network US_Vlan_14
 subnet 10.83.132.0 255.255.255.0
object network INvlan200
 subnet 10.145.49.0 255.255.255.0
object network OutsideIPv4Gateway
 host 210.666.111.1
object network OutsideIPv4DefaultRoute
object-group network |s2sAclSrcNwgV4|829f4535-aecf-11e9-b03c-d9fb9a86cd36
 network-object object 10.145_16
object-group network |s2sAclDestNwgV4|829f4535-aecf-11e9-b03c-d9fb9a86cd36
 network-object object US_Vlan_600
 network-object object US_Vlan_14
access-list NGFW_ONBOX_ACL remark rule-id 268435458: ACCESS POLICY: NGFW_Access_Policy
access-list NGFW_ONBOX_ACL remark rule-id 268435458: L5 RULE: US-to-India
access-list NGFW_ONBOX_ACL advanced permit ip object USinternetAddresses ifc outside any rule-id 268435458
access-list NGFW_ONBOX_ACL remark rule-id 268435460: ACCESS POLICY: NGFW_Access_Policy
access-list NGFW_ONBOX_ACL remark rule-id 268435460: L5 RULE: USvln14-0to-INvlan200
access-list NGFW_ONBOX_ACL advanced permit ip object US_Vlan_14 object INvlan200 rule-id 268435460
access-list NGFW_ONBOX_ACL advanced permit ip object US_Vlan_600 object INvlan200 rule-id 268435460
access-list NGFW_ONBOX_ACL remark rule-id 268435461: ACCESS POLICY: NGFW_Access_Policy
access-list NGFW_ONBOX_ACL remark rule-id 268435461: L5 RULE: INvlan200-to-USvlan14
access-list NGFW_ONBOX_ACL advanced permit ip object INvlan200 object US_Vlan_14 rule-id 268435461
access-list NGFW_ONBOX_ACL advanced permit ip object INvlan200 object US_Vlan_600 rule-id 268435461
access-list NGFW_ONBOX_ACL remark rule-id 268435459: ACCESS POLICY: NGFW_Access_Policy
access-list NGFW_ONBOX_ACL remark rule-id 268435459: L5 RULE: OutSide-to-any
access-list NGFW_ONBOX_ACL advanced permit ip ifc outside any any rule-id 268435459
access-list NGFW_ONBOX_ACL remark rule-id 268435457: ACCESS POLICY: NGFW_Access_Policy
access-list NGFW_ONBOX_ACL remark rule-id 268435457: L5 RULE: Inside_Outside_Rule
access-list NGFW_ONBOX_ACL advanced trust ip ifc inside any ifc outside any rule-id 268435457 event-log both
access-list NGFW_ONBOX_ACL remark rule-id 1: ACCESS POLICY: NGFW_Access_Policy
access-list NGFW_ONBOX_ACL remark rule-id 1: L5 RULE: DefaultActionRule
access-list NGFW_ONBOX_ACL advanced deny ip any any rule-id 1
access-list |s2sAcl|829f4535-aecf-11e9-b03c-d9fb9a86cd36 extended permit ip object-group |s2sAclSrcNwgV4|829f4535-aecf-11e9-b03c-d9fb9a86cd36 object-group |s2sAclDestNwgV4|829f4535-aecf-11e9-b03c-d9fb9a86cd36
pager lines 24
logging enable
logging timestamp
logging console warnings
mtu diagnostic 1500
mtu outside 1500
mtu inside 1500
no failover
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 32768
nat (inside,outside) source static |s2sAclSrcNwgV4|829f4535-aecf-11e9-b03c-d9fb9a86cd36 |s2sAclSrcNwgV4|829f4535-aecf-11e9-b03c-d9fb9a86cd36 destination static |s2sAclDestNwgV4|829f4535-aecf-11e9-b03c-d9fb9a86cd36 |s2sAclDestNwgV4|829f4535-aecf-11e9-b03c-d9fb9a86cd36 no-proxy-arp route-lookup
nat (inside,outside) source static 10.145_16 10.145_16 destination static Vlan_14 Vlan_14
nat (any,outside) after-auto source dynamic any-ipv4 interface
access-group NGFW_ONBOX_ACL global
route outside 0.0.0.0 0.0.0.0 210.666.111.1 1
route inside 10.145.0.0 255.255.0.0 10.145.49.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication login-history
http server enable
http 0.0.0.0 0.0.0.0 inside
http ::/0 inside
ip-client diagnostic ipv6
ip-client inside ipv6
ip-client inside
ip-client outside ipv6
ip-client outside
no snmp-server location
no snmp-server contact
sysopt connection tcpmss 0
crypto ipsec ikev2 ipsec-proposal VPN_IPSEC_PRO
 protocol esp encryption aes-gcm-256
 protocol esp integrity null
crypto ipsec security-association pmtu-aging infinite
crypto map s2sCryptoMap 1 match address |s2sAcl|829f4535-aecf-11e9-b03c-d9fb9a86cd36
crypto map s2sCryptoMap 1 set peer 216.55.11.82
crypto map s2sCryptoMap 1 set ikev2 ipsec-proposal VPN_IPSEC_PRO
crypto map s2sCryptoMap interface outside
crypto ca trustpool policy
crypto ikev2 policy 1
 integrity null
 group 19
 prf sha256
 lifetime seconds 86400
crypto ikev2 enable outside
crypto ikev1 policy 160
 authentication pre-share
 encryption des
 hash sha
 group 5
 lifetime 86400
telnet timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
group-policy |s2sGP|216.55.11.82 internal
group-policy |s2sGP|216.55.11.82 attributes
 vpn-tunnel-protocol ikev2
dynamic-access-policy-record DfltAccessPolicy
tunnel-group 216.55.11.82 type ipsec-l2l
tunnel-group 216.55.11.82 general-attributes
 default-group-policy |s2sGP|216.55.11.82
tunnel-group 216.55.11.82 ipsec-attributes
 ikev2 remote-authentication pre-shared-key *****
 ikev2 local-authentication pre-shared-key *****
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
  no tcp-inspection
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
  inspect icmp error
service-policy global_policy global
prompt hostname context
app-agen heartbeat interval 1000 retry-count 3
snort preserve-connection
Cryptochecksum:7bffc7f714679427fd4645c16fb65a91
: end
You'll need a NAT exemption rule. You need to ensure the original & translated source is INvlan200 and the original & translated destination is US_Vlan_14 (assuming those are the correct objects). Create another rule for the other objects, or reference a group containing all objects instead.
Here is a similar example:-
You will also need to ensure the Access Control Policy permits the traffic.
EDIT: Sorry, I wasn't as observant as @Rahul Govindan you seem to already have the NAT rule.
Rahul Govindan
Your config looks correct. You have the right NAT, ACL and route,
 What about the other side? Do you have the config?
Yeah, I have the config for The other side. It looks like this.
: Saved
NGFW Version 6.2.3.13
hostname firepower
 description internet facing
 nameif WAN
 cts manual
 security-level 0
 ip address 216.55.11.82 255.255.255.240
 management-only
 nameif diagnostic
 cts manual
 security-level 0
 no ip address
ftp mode passive
object network 10.83.138.0
object network VLAN_26
 subnet 10.83.135.0 255.255.255.0
object network VLAN600
access-list CSM_FW_ACL_ remark rule-id 9998: PREFILTER POLICY: Default Tunnel and Priority Policy
access-list CSM_FW_ACL_ remark rule-id 9998: RULE: DEFAULT TUNNEL ACTION RULE
access-list CSM_FW_ACL_ advanced permit ipinip any any rule-id 9998
access-list CSM_FW_ACL_ advanced permit 41 any any rule-id 9998
access-list CSM_FW_ACL_ advanced permit gre any any rule-id 9998
access-list CSM_FW_ACL_ advanced permit udp any eq 3544 any range 1025 65535 rule-id 9998
access-list CSM_FW_ACL_ advanced permit udp any range 1025 65535 any eq 3544 rule-id 9998
access-list CSM_FW_ACL_ remark rule-id 268438531: ACCESS POLICY: US - Mandatory
access-list CSM_FW_ACL_ remark rule-id 268438531: L7 RULE: DRvl37-to-VBvl600
access-list CSM_FW_ACL_ advanced permit ip ifc WAN object DRvlan37_52 object 10.83.138.0 rule-id 268438531
access-list CSM_FW_ACL_ remark rule-id 268438533: ACCESS POLICY: US - Mandatory
access-list CSM_FW_ACL_ remark rule-id 268438533: L7 RULE: VLAN14-to-DRVL39
access-list CSM_FW_ACL_ advanced permit ip ifc WAN any ifc WAN any rule-id 268438533
access-list CSM_FW_ACL_ remark rule-id 268438530: ACCESS POLICY: US - Mandatory
access-list CSM_FW_ACL_ remark rule-id 268438530: L7 RULE: VLAN26_TO_WAN
access-list CSM_FW_ACL_ advanced permit ip ifc WAN any ifc VLAN_26 any rule-id 268438530
access-list CSM_FW_ACL_ advanced permit ip ifc VLAN_26 any ifc WAN any rule-id 268438530
access-list CSM_FW_ACL_ advanced permit ip ifc VLAN_26 any ifc VLAN_26 any rule-id 268438530
access-list CSM_FW_ACL_ remark rule-id 268436484: ACCESS POLICY: US - Default
access-list CSM_FW_ACL_ remark rule-id 268436484: L4 RULE: DEFAULT ACTION RULE
access-list CSM_FW_ACL_ advanced deny ip any any rule-id 268436484 event-log flow-start
access-list VPN_IP_POOL standard permit 172.16.10.0 255.255.254.0
access-list AnyConnect_Split standard permit 10.83.138.0 255.255.255.0
access-list CSM_IPSEC_ACL_3 extended permit ip 10.83.138.0 255.255.255.0 10.145.0.0 255.255.0.0
access-list CSM_IPSEC_ACL_3 extended permit ip 10.83.132.0 255.255.255.0 10.145.0.0 255.255.0.0
tcp-map UM_STATIC_TCP_MAP
  tcp-options range 6 7 allow
  tcp-options range 9 18 allow
  tcp-options range 20 255 allow
  urgent-flag allow
no pager
logging list MANAGER_VPN_EVENT_LIST level errors class auth
logging list MANAGER_VPN_EVENT_LIST level errors class vpn
logging list MANAGER_VPN_EVENT_LIST level errors class vpnc
logging list MANAGER_VPN_EVENT_LIST level errors class vpnfo
logging list MANAGER_VPN_EVENT_LIST level errors class vpnlb
logging list MANAGER_VPN_EVENT_LIST level errors class webfo
logging list MANAGER_VPN_EVENT_LIST level errors class webvpn
logging list MANAGER_VPN_EVENT_LIST level errors class ca
logging list MANAGER_VPN_EVENT_LIST level errors class svc
logging list MANAGER_VPN_EVENT_LIST level errors class ssl
logging list MANAGER_VPN_EVENT_LIST level errors class dap
logging list MANAGER_VPN_EVENT_LIST level errors class ipaa
logging FMC MANAGER_VPN_EVENT_LIST
no logging message 106015
no logging message 313001
no logging message 313008
no logging message 106023
no logging message 710003
no logging message 106100
no logging message 302015
no logging message 302014
no logging message 302013
no logging message 302018
no logging message 302017
no logging message 302016
no logging message 302021
no logging message 302020
mtu WAN 1500
mtu VLAN_26 1500
mtu VLAN_25 1500
mtu VLAN_800 1500
mtu VLAN_501 1500
mtu diagnostic 1500
failover
failover lan unit secondary
failover lan interface Sync_Link Ethernet1/11
failover replication http
failover link Sync_Link Ethernet1/11
failover interface ip Sync_Link 10.10.10.1 255.255.255.0 standby 10.10.10.2
arp timeout 14400
access-group CSM_FW_ACL_ global
route WAN 0.0.0.0 0.0.0.0 216.55.11.19 1
route WAN 10.145.49.0 255.255.255.0 210.666.111.1 1
route WAN 210.666.111.1 255.255.255.255 216.55.11.19 1
timeout tcp-proxy-reassembly 0:00:30
aaa-server ad500-remote-access protocol ldap
 max-failed-attempts 4
 realm-id 3
aaa-server ad500-remote-access host 10.83.138.30
 server-port 389
 ldap-base-dn DC=A,DC=net
 ldap-group-base-dn CN=Users,DC=A,DC=net
 ldap-scope subtree
 ldap-naming-attribute samaccountname
 ldap-login-password *****
 ldap-login-dn vpn@a.net
 server-type microsoft
aaa proxy-limit disable
no snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev2 ipsec-proposal CSM_IP_1
crypto map CSM_WAN_map 1 match address CSM_IPSEC_ACL_2
crypto map CSM_WAN_map 1 set peer 147.
crypto map CSM_WAN_map 1 set ikev2 ipsec-proposal CSM_IP_1
crypto map CSM_WAN_map 1 set reverse-route
crypto map CSM_WAN_map 2 match address CSM_IPSEC_ACL_3
crypto map CSM_WAN_map 2 set peer 210.666.111.1
crypto map CSM_WAN_map 2 set ikev2 ipsec-proposal CSM_IP_1
crypto map CSM_WAN_map 2 set reverse-route
crypto map CSM_WAN_map interface WAN
crypto ca trustpoint r.a.net
 enrollment self
 subject-name CN=r.a.net
 keypair <Default-RSA-Key>
 ignore-ipsec-keyusage
 crl configure
crypto ca certificate chain r.a.net
 certificate 78631b5d
  quit
crypto ikev2 policy 2
 integrity null
 group 19
 prf sha256
crypto ikev2 policy 10
 encryption aes-gcm-256 aes-gcm-192 aes-gcm
 integrity null
 group 21 20 19 14 5
 prf sha512 sha384 sha256 sha
crypto ikev2 enable WAN
crypto ikev1 am-disable
telnet timeout 5
console timeout 0
tls-proxy maximum-session 1000
ssl trust-point r.a.net
webvpn
 enable WAN
 anyconnect image disk0:/csm/anyconnect-win-4.7.02036-webdeploy-k9.pkg 1 regex "Windows"
 anyconnect image disk0:/csm/anyconnect-linux64-4.7.02036-webdeploy-k9.pkg 2 regex "Linux"
 anyconnect image disk0:/csm/anyconnect-macos-4.7.02036-webdeploy-k9.pkg 3 regex "Mac OS"
 anyconnect enable
 tunnel-group-list enable
 cache
  no disable
group-policy DfltGrpPolicy attributes
 vpn-tunnel-protocol ikev2 ssl-client
 user-authentication-idle-timeout none
 webvpn
  anyconnect keep-installer none
  anyconnect modules value dart
  anyconnect ask none default anyconnect
  http-comp none
  activex-relay disable
  file-entry disable
  file-browsing disable
  url-entry disable
  deny-message none
group-policy RA_FullTunnel internal
group-policy RA_FullTunnel attributes
 banner none
 wins-server none
 dns-server value 10.83.138.30
 dhcp-network-scope none
 vpn-simultaneous-logins 3
 vpn-idle-timeout 30
 vpn-idle-timeout alert-interval 1
 vpn-session-timeout none
 vpn-session-timeout alert-interval 1
 vpn-filter none
 split-tunnel-policy tunnelall
 ipv6-split-tunnel-policy tunnelall
 split-tunnel-network-list none
 default-domain value A.net
 split-dns none
 split-tunnel-all-dns disable
 client-bypass-protocol disable
 vlan none
 address-pools value RemoteAccess-IP-Pool
 webvpn
  anyconnect ssl dtls enable
  anyconnect mtu 1406
  anyconnect firewall-rule client-interface public none
  anyconnect firewall-rule client-interface private none
  anyconnect ssl keepalive 20
  anyconnect ssl rekey time none
  anyconnect ssl rekey method none
  anyconnect dpd-interval client 30
  anyconnect dpd-interval gateway 30
  anyconnect ssl compression none
  anyconnect dtls compression none
  anyconnect ssl df-bit-ignore disable
group-policy RA_SplitTunnel internal
group-policy RA_SplitTunnel attributes
 banner none
 wins-server none
 vpn-idle-timeout 30
 vpn-filter none
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value AnyConnect_Split
 default-domain value AD500.net
 split-dns none
 vlan none
 webvpn
  anyconnect mtu 1406
group-policy VPN_temp internal
group-policy VPN_temp attributes
 banner value wt
 wins-server none
 vpn-idle-timeout 30
 vpn-filter none
 vpn-tunnel-protocol ssl-client
 split-tunnel-network-list value VPN_IP_POOL
 default-domain none
 split-dns none
 vlan none
 webvpn
  anyconnect mtu 1406
group-policy .DefaultS2SGroupPolicy internal
group-policy .DefaultS2SGroupPolicy attributes
 vpn-idle-timeout 30
 vpn-filter none
 vpn-tunnel-protocol ikev1 ikev2
tunnel-group 147. type ipsec-l2l
tunnel-group 147. general-attributes
 default-group-policy .DefaultS2SGroupPolicy
tunnel-group 147. ipsec-attributes
tunnel-group remote-Access type remote-access
tunnel-group remote-Access general-attributes
 address-pool RemoteAccess-IP-Pool
 authentication-server-group a-remote-access
 default-group-policy RA_SplitTunnel
tunnel-group remote-Access webvpn-attributes
 group-alias remote-Access enable
tunnel-group 210.666.111.1 type ipsec-l2l
tunnel-group 210.666.111.1 general-attributes
tunnel-group 210.666.111.1 ipsec-attributes
 parameters
  no tcp-inspection
policy-map type inspect ip-options UM_STATIC_IP_OPTIONS_MAP
 parameters
  eool action allow
  nop action allow
  router-alert action allow
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
  inspect icmp error
 class class-default
  set connection advanced-options UM_STATIC_TCP_MAP
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
app-agent heartbeat interval 1000 retry-count 3
Cryptochecksum:eeca95f4583f64f8693d6fd8a516e8e5
: end
: Saved
hostname firepower
 nameif WAN
 cts manual
 security-level 0
 management-only
 nameif diagnostic
 cts manual
 security-level 0
 no ip address
ftp mode passive
  urgent-flag allow
no pager
mtu WAN 1500
mtu VLAN_26 1500
mtu VLAN_25 1500
mtu VLAN_800 1500
mtu VLAN_501 1500
mtu diagnostic 1500
failover
arp timeout 14400
aaa-server a-remote-access protocol ldap
 realm-id 3
aaa-server a-remote-access host 10.83.138.30
 server-port 389
 ldap-scope subtree
 enrollment self
 crl configure
  quit
 integrity null
 group 19
 prf sha256
 integrity null
 group 21 20 19 14 5
telnet timeout 5
console timeout 0
webvpn
 enable WAN
 anyconnect enable
 cache
  no disable
 webvpn
  http-comp none
  file-entry disable
  url-entry disable
  deny-message none
 banner none
 wins-server none
 vpn-idle-timeout 30
 vpn-filter none
 split-dns none
 vlan none
 webvpn
  anyconnect mtu 1406
 banner none
 wins-server none
 vpn-idle-timeout 30
 vpn-filter none
 split-dns none
 vlan none
 webvpn
  anyconnect mtu 1406
 banner value wt
 wins-server none
 vpn-idle-timeout 30
 vpn-filter none
 default-domain none
 split-dns none
 vlan none
 webvpn
  anyconnect mtu 1406
 vpn-idle-timeout 30
 vpn-filter none
 parameters
  no tcp-inspection
 parameters
  eool action allow
  nop action allow
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
  inspect icmp error
 class class-default
call-home
 profile CiscoTAC-1
  no active
: end
