File Copy issue to ASA firewall standby unit using SCP
I am using Cisco ASA5525 firewalsl in active standby mode. It is running on version 9.9. I want to upgrade it to 9.12 version.
I have copied the image file to active unit using scp. however when i try to copy the file to standby unit, it gives me below error
# failover exec mate copy /noconfirm scp://test@172.31.21.37://home/test/asa9-12-3-smp-k8.bin disk0:
Accessing scp://test@172.31.21.37//home/test/asa9-12-3-smp-k8.bin....
Password:
%Error opening scp://test@172.31.21.37//home/test/asa9-12-3-smp-k8.bin (Permission denied)
Sheraz.Salim
Make sure 'ssh copy enable/ssh scopy enable' is on, and that ssh for that ip/subnet is enabled.
then scp from one ASA to the other
ASA# copy /noconfirm asa917-12-smp-k8.bin scp://username:password@IP_Addr/asa917-12-smp-k8.bin
I don't like having to put the password in clear text on the command line, but it doesn't seem to prompt interactively for a password. (even if I don't use /noconfirm)
please do not forget to rate.
