Showing results forĀ
Search instead forĀ
Did you mean:Ā
Fire Power 9300 Management
As per the document there is Firepower Supervisor management console for managing firepower 9300.Can we manage this using FMC as well?
Also document says it needs to communication to license center at least every 90 days. Is there an option to do offline licensing?
Saw an option to do it via smart license manager satellite which needs OVA file  to be installed on vmware esxi server. From this server do we need internet access to license center?Also seen an option for permanent license for FXOS chassis.Anyone can explain that as well?
We have Firepower 9300 with single security module installed. Will this have all functionality like AMP,url filtering,AVC if we have the license.Do we need seprate security module for each.
Also need to know if Can we do a manual update for IPS,security intelligence ,AVC etc?
2 Accepted Solutions
Marvin Rhoads
Duplicate post. Answered here:
https://supportforums.cisco.com/discussion/13011701/firepower-9300-license-issues
You're welcome.
It can be done manually as confirmed in the product FAQ:
http://www.cisco.com/c/dam/en/us/products/collateral/cloud-systems-management/smart-software-manager-satellite/q-and-a-c67-734541.pdf
Please rate the answers that help and mark your question as answered when it has been.
Marvin Rhoads
Thanks Marvin for detailed explanation.
Just to clarify , For Smart Software Manager Satellite do we need to have access to internet periodically or we can do it manually?
You're welcome.
Hello Marvin
As mentioned in the document we can install the Smart Software Manager Satellite iso file as well. I cannot see any ISO file in cisco website?Only available is .ova file with vmware.Do you have any link for the same so that we can install on any server or PC.
Also What is the best way to update if we don't have internet access? I mean to update the below
Rules Updates
SEU
VDB
GeoDB
We should do it manually or we have any other solution for this?
Also if there is firesight 4000 appliance with version 5.4.1 can we re image it to 6.2.0 the latest version as per the link mentioned below.We dont want to go through upgrade path which is time consuming.Also its fresh installation.Firesight has 16GB ram and 800G hard disk,16G Flash
http://www.cisco.com/c/en/us/support/docs/security/firesight-management-center/118308-technote-firesight-00.html
