Fire Power appliances Vs. ether-channel
egsuptac911
can any one advice how to deploy firepower box in running environment , also does it support ether-channel if the network is running in this manner
BR
Hazem Hafez
5 Replies 5
yogdhanu
If you planning to deploy the box inline , just plug it in between your switches as it would be in layer 2 transparent mode, so you don't need any special config in there.
Are you looking at anything specific ?
Yogesh
what if the switches are ether channel  connected will it support ?
BR
Hazem
Hello Hazem,
As per the short description that you provided ,the setup will work.
Here is the quick reference link which will give you more insight :-
http://www.cisco.com/c/en/us/support/docs/security/sourcefire-firepower-8000-series-appliances/117897-cinfig-sourcefire-00.html
Jetsy
Hi Mathew,
I wonder when using 4110 Chassis, which is the best practice to deploy an etherchannel.
Should we configure it from the FMC which is controlling the virtual FTD (deployed in the chassis) or should we first create the etherchannel in Chassis manager ui, then deploy the FTD containing that etherchannel, and finally use it in my firewall configuration.
Many thanks
Sadik
You need to first allocate/assign the interfaces and bond them into an Etherchannel in the Firepower Chassis Manager. Then configure and deploy the etherchannel interface address etc. from FMC.
