Firepower RAVPN with Outside interface using private address
jdonjuanl
Level 3
Level 3
Hello, we are implementing a RAVPN solution with Firepower and the scenario is:
-We have a x.x.x.x/30 for RAVPN solution
-Firepower Outisde interface is using private address y.y.y.y/30 and is connected to a Internet Router inside interface
-Internet Router is also using private addressing for inside and outside interfaces
-Internet Router has a static route indicating the x.x.x.x/30 lives in the firewall and the next-hop is the Firepower Outside interface.
LAN <---> FP <----> Router <-----> Internet
It is possible to deploy RAVPN in this scenario?
Can anyone send any documentation to implement it?
jdonjuanl
Level 3
Level 3
As far I can tell it is not possible
JCD
jdonjuanl
Level 3
Level 3
JCD
Cristian Matei
   If you can't assign the public IP to the FTD directly, you can configure the router in front of the FTD to perform NAT, and make the FTD private address visible as the public address to the Internet.
Cristian Matei.
