Firepower Sensor Shutdown Reboot Question
QUARK TARO
Level 3
Level 3
How can I shutdown the IPS sensor on ASA5525-X with Firepower.
I have issued the command from Firesight Console under devices but still I am able to ping the IPS sensor management IP from other system.
In the Firesight console it shows the sensor as down.
What is the right method to shutdown the sensors?
Also after the sensor shutdown, how can I power-on the sensor without rebooting the firewall?
17 Replies 17
It appears to be totally offline. Have you verified the SSD is being seen with "show inventory"?
You may have to re-image and/or replace the SSD. If it's the SSD and you don't have support, the module may be unrecoverable.
Here is the output of sh inventory:
hoasa01# show inventory
Name: "Chassis", DESCR: "ASA 5525-X with SW, 8 GE Data, 1 GE Mgmt, AC"
PID: ASA5525 , VID: V06 , SN: FTX2250W0A2
Name: "Storage Device 1", DESCR: "Model Number: Micron_M550_MTFDDAK128MAY"
PID: N/A , VID: N/A , SN: MXA190801MM
