11-26-2009 06:33 AM - edited 03-11-2019 09:43 AM
I've the problem with a VPN-client. After he connected to the Oracle-server he sends sql-requests to the server. But the ASA5520 Version 8.0(4) terminates the connection with: Flow closed by inspection.
Does anybody know how to solve this problem? Thanks
Solved! Go to Solution.
11-26-2009 10:30 AM
Upgrade to 8.0.5 or at least to some interim release after 8.0(4.16). I also had some problems, which were fixed by upgrade to newer release of software.
Mirek
11-26-2009 10:30 AM
Mirek
11-27-2009 05:59 AM
Thanks a lot!
You hit the bull's eye. I upgraded to 8.2 and all is running fine!
