FPR1010-ASA-K9 max. users and max. VPN
Eduardo Lara
I am unable to find the included and the max. numbers of users and VPN peers for the new FPR1010-ASA-K9. (ASA Image)
Thanks a lot in advanced.
EL.
5 Replies 5
Thanks, I know 75 is max vpn peer but i need to know if It is included in
the standard license or it needs a Security Plus or other purchased licence?
Thanks.
Thanks, I know 75 is max vpn peer but i need to know if It is included in the standard license or it needs a Security Plus or other purchased licence?
Thanks.
ASA K9 have two mode Base and Security Plus.
so Base License
AnyConnect Premium Peers : 2 perpetual
AnyConnect Essentials : Disabled perpetual
Other VPN Peers : 10 perpetual
Total VPN Peers : 12 perpetual
found this one it will help you here
go all the way down to configure licensing
please do not forget to rate.
Good, Thanks, that is I am looñong for. Can you share the link or document where you found these information?
Have you the answer for my question about users limit?
Thanks a lot.
