10-04-2023 10:21 AM
I would like to clear the most used statistic in the output of show conn count on my FPW4110 running an ASA 9.14(4) 17
example Output of show conn count
1234 in use, 991234 most used
I would like to reset the most used figure
if this was an older ASA 5515, 5508 or one of the smaller FPW models running in ASA mode etc I would run the command Clear resource usage resource conns which would do the trick. However this syntax seems to be unsupported on this device. Any idea how I might do this? My google-fu has failed me this time..
Many thanks
Solved! Go to Solution.
10-10-2023 09:57 AM
I found some other FPW chassis 4110 and 4112 that this command works on those running the same version as the one I have the problem with. I can only assume its an odd bug and it will probably disappear when the box is next reloaded. many thanks for the assistance everyone.
10-04-2023 05:58 PM
the command should still work on 9.14 as per reference (i dont have device to test now) - we moved to firepower
10-05-2023 02:11 AM
Thats what I was expecting too, and you are correct for FPW1112 and smaller they work fine. sadly these bigger boxes with FXOS and a virtual ASA on them seem to behave differently. I experience the same issue on a FPW2120 running ASA 9.14(4)6
clear r? gives options for clear route only.
Perhaps its something that needs doing at the FXOS level like NTP. I just cant seem to find any info on it anywhere Thanks for replying though
10-05-2023 08:13 AM
This is strange, because this CLI is available on my Firepower 4145 / 9.16.4.14.
10-05-2023 03:13 AM
How you control this FPR ?
Fdm or fmc ?
10-05-2023 03:33 AM
SSH only no other management tool.
10-05-2023 10:11 AM
Your FPR is 1000 ?
10-05-2023 10:15 AM
FPW4110 doesn't work
1010 does.
i am wondering if we are hitting a bug where some commands become non functional after some time online, we have experienced this on the FXOS side before which required a reboot to fix but not on the ASA side..
10-10-2023 09:57 AM
