FTD 4100 Clustring problem
Mohammed.Fawzi
Frequent Visitor
Frequent Visitor
Hi everyone
I have this confusing problem with clustering two FTD 4100 series, when copying the cluster configuration from the first one to the other one, it stays at this state all the time and not give even an error
notice that I have both FTD have 2 port channels on the core switch that they attached to and its (Huawei) and its running fine and they both at the same VLAN
please if someone can
Chakshu Piplani
This might be due to https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuw53588 can you try to do the config manually and form the cluster.
Chakshu
Do rate helpful posts by leaving your kudos/mark it as solved.
What do you mean by do the config manually?
i mean there is two way :
one create new cluster (master)
and one for joining cluster (slave)
plus if i upgrade FXOS would it solve the problem?
