FTD Firewall MGMT interface Management Advice
Darshin Gadhia
hi Team
i have FTD 4120 where MGMT interface available to manage Chassis.
can i assign that MGMT interface to other onboard available interface
regards,
darshin
Chts
Level 4
Level 4
Didn't get this- can i assign that MGMT interface to other onboard available interface.
Actually , Firepower 4100 series MGMT interface is only for Chassis Management. If you create any logical devices ( ex: ASA or FTD) on the chassis you have to use one of the data interface as a management interface for logical devices ( interface type should be change to mgmt. before assigning to the Logical devices. hope this helps.
