FTP not working when ACL is applied on outside interface
mahesh18
Level 6
Level 6
Hi Everyone,
I am trying to FTP  from the PC  behind the DMZ  interface.
I have config the ACL to allow FTP from outside interface direction is outside.
I can make the FTP work by config of ACL on the DMZ interface but i want to test it so that it can work from my PC behind DMZ interface when i apply ACL on the  outside interface direction is out.
I have attached the asa config.
Need to know if there is any way under current config that FTP can work without applying ACL to DMZ interface?
2 Accepted Solutions
I can't look at your config at the moment (doesn't work on the iPad), but one alternative to an ACL on the DMZ interface could be to use a global ACL.
Apply that acl in incoming direction on outside interface.
no, the ASA is a statefull Firewall with FTP-Inspection. You never need an incoming ACL in the outside interface for outbound FTP when you have a proper config.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Hi Mahesh,
Cheers
Pankaj
Hi Karsten,
Your answers are good to read and they  have so much knowledge.
For time being i allowed ftp to any destination from DMZ  but on outbound interface direction out  i have restricted it with
certain IP  which are allowed.
Best regards
Mahesh
