FWSM system space does not replicate part of configuration
pslavkovsky
I have FWSM failover pair, Active/Active configuration, admin and another 4 context, few context active on first FWSM, other on second FWSM.
I needed to add  VLANs 51 and 52 to FWSM
I created VLANs on both Cat6500, created firewall vlan-group 3 a and put "firewall module1 vlan-group 3" on both cat6500
Then I log in in system space on primary FWSM and created interface VLAN.
Created VLANs automatically occured in system space on  Secondary FWSM.
Then I wanted allocate VLAN 51 and 52 to context XY, so I went to part of configuration for context XY and "allocate-interface Vlan51" and  "allocate-interface Vlan52".
But this part did not replicate to system space on Secondary FWSM, i do not know why.
I tried for expample shutdown inteface101 in system space on Primary FWSM. This action was replicated.
pnfkepolsa17# sh failover state
====My State===
Primary | Active |
====Other State===
Secondary | Standby |
====Configuration State===
       Interface config Syncing - STANDBY
       Sync Done - STANDBY
====Communication State===
       Mac set
=========Failed Reason==============
My Fail Reason:
Other Fail Reason:
pnfkepolsa17#
====My State===
====Other State===
Primary | Active |
       Sync Done
       Sync Done - STANDBY
       Mac set
My Fail Reason:
Other Fail Reason:
       Comm Failure
pnfkepolsa17#
I found this message in logg of Cat6500
000160: Jun 11 20:34:22.405: %SVCLC-5-SVCLCMULTI: Group 3 being tied to more than one module
Why is this problem?
Peter
pslavkovsky
I found explanation:
Error Message    %SVCLC-5-SVCLCMULTI: Group [dec] being tied to more than one module
Explanation    The specified group is tied to multiple service modules. A group should not be associated with more than one service module unless a failover configuration is being used.
Recommended Action    If a failover configuration is in use, no action is required. Otherwise enter the show svclc module command to find out which group is being tied to more than one module. Then remove multiple associations by entering the no svclc module mod vlan-group group command.
I want to use vlan-group 3 for FWSM and for ACE module too.
which kind of failover was mentioned?
Peter
