Help me in Natting
pawanharlecisco
Hi ,
    Please see the daigram attached .
I have Internet leased line which is connected  to "Outside "Interface of ASA 5510.I address are mentioned in Daigram.
I have Few Public IP address given by ISP. I want to do static  NAT in ASA for accessing my server from Internet, i am fresher in configuring  ASA ,please guide me .I have also want 192.168.5.10;  192.168.5.11; 192.168.5.12;  192.168.5.13 this IP ca use Internet also, for OS updates
Public ip 2.2.2.5  mapped to 192.168.5.10
Public ip 2.2.2.6  mapped to 192.168.5.11
Public ip 2.2.2.7  mapped to 192.168.5.12
Public ip 2.2.2.8  mapped to 192.168.5.13
Please guide me.
22 Replies 22
Hi Pawan,
We cannot have two default routes on the ASA, the packet would always take the route defined by lower mettric which is:
route outside 0.0.0.0 0.0.0.0 2.2.2.1 1
I am not sure why you are implementing such a thing, you have two interfaces configured through which the same internal network would access internet, so that would get complicated.
If you are just testing the bsnl modem link, remove the first route and then add:
route outside 0.0.0.0 0.0.0.0 192.168.100.1 1
and moreover on interface e0, you have a private IP address, and we woudl need a public IP like 2.2.2.2 to access the internet.
Also these access-list are not needed:
access-list OUTIN extended permit ip any any
access-list inside_access_in extended permit tcp any any
access-list inside_access_in extended permit tcp host 192.168.5.2 interface outside
Let me know if this works.
Varun
Varun Rao
Sir,
     i want use bsnl as my default route. and give static route for servers because there are only some specific ip add which will acess the server thats y no need give default route towards 2.2.2.1.
Now my purpose the that,
1: the network 192.168.5.0 will use internet using bsnl line
2:and is some specific ip add want to access the server then they have to use 2.2.2.0 newtork which we was statically natted earlier.
Hi Pawan,
as per your requirement here is the config that you can try:
static (inside,outside) 2.2.2.5 192.168.5.10 netmask 255.255.255.255
static (inside,outside) 2.2.2.6 192.168.5.11 netmask 255.255.255.255
static (inside,outside) 2.2.2.7 192.168.5.12 netmask 255.255.255.255
access-list 101 permit ip any host 2.2.2.5
access-list 101 permit ip any host 2.2.2.6
access-list 101 permit ip any host 2.2.2.7
nat (outside) 10 access-list 101 outside
global (inside) 10 interface
The above configuration would allow only traffic from your 2.2.2.1 router for you internal servers.
the routes should be:
route outside 0.0.0.0 0.0.0.0 2.2.2.1 100
nat (inside) 1 0.0.0.0 0.0.0.0
global (bsnl) 1 interface.
Try it and let me know if it works.
Varun
Varun Rao
thank you sir,it done sucessfully .
please c below config. If still need any change tell me.From below config if there is any useless command i configured,please guide  me so that i can remove it.
hostname pixfirewall
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address 192.168.100.200 255.255.255.0
interface Ethernet1
nameif inside
security-level 100
ip address 192.168.5.1 255.255.255.0
interface Ethernet2
nameif rbi
security-level 0
ip address 2.2.2.2 255.255.255.0
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
access-list 101 extended permit ip any host 2.2.2.5
access-list 101 extended permit ip any host 2.2.2.6
access-list 101 extended permit ip any host 2.2.2.7
access-list outside-in extended permit icmp any any
access-list outside-in extended permit ip any any
pager lines 24
mtu outside 1500
mtu inside 1500
mtu rbi 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
static (inside,rbi) 2.2.2.5 192.168.5.10 netmask 255.255.255.255
static (inside,rbi) 2.2.2.6 192.168.5.11 netmask 255.255.255.255
static (inside,rbi) 2.2.2.7 192.168.5.12 netmask 255.255.255.255
access-group outside-in in interface outside
access-group 101 in interface rbi
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
prompt hostname context
Cryptochecksum:00000000000000000000000000000000
: end
pixfirewall#
Hi Pawan,
Everything looks good to me except these lines below, intsead of them you need to add these:
nat (rbi) 10 access-list 101 outside
route rbi 0.0.0.0 0.0.0.0 2.2.2.1 100
and remove this statement:
we don't need it, the access-list 101 was created just to be used in the nat statement.
interface Ethernet2
nameif rbi
security-level 0
Hope this works,
Varun
Varun Rao
Dear Varun Sir,
                         Thanks for your help and support...
Finaly because of you only i have done this sucessfully.
Please have a look for final config.
hostname ASA
names
interface Ethernet0
nameif outside
security-level 0
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
nameif juniper
security-level 0
ip address 10.34.249.50 255.255.255.224
interface Ethernet3
nameif dmz
security-level 10
ip address 192.168.6.1 255.255.255.0
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
ftp mode passive
access-list juniper-in extended permit ip any host 10.34.249.35
access-list juniper-in extended permit ip any host 10.34.249.36
access-list juniper-in extended permit ip any host 10.34.249.37
access-list dmz-in extended permit ip any any
access-list dmz-in extended permit icmp any any
access-list dmz-in extended permit ip any host 10.34.249.35
access-list dmz-in extended permit ip any host 10.34.249.36
access-list dmz-in extended permit ip any host 10.34.249.37
pager lines 24
mtu outside 1500
mtu inside 1500
mtu juniper 1500
mtu dmz 1500
arp timeout 14400
nat (outside) 10 access-list juniper-in outside
static (inside,juniper) 10.34.249.35 192.168.5.10 netmask 255.255.255.255
static (inside,juniper) 10.34.249.36 192.168.5.11 netmask 255.255.255.255
static (inside,juniper) 10.34.249.37 192.168.5.12 netmask 255.255.255.255
static (inside,dmz) 10.34.249.35 192.168.5.10 netmask 255.255.255.255
static (inside,dmz) 10.34.249.36 192.168.5.11 netmask 255.255.255.255
static (inside,dmz) 10.34.249.37 192.168.5.12 netmask 255.255.255.255
access-group juniper-in in interface juniper
access-group dmz-in in interface dmz
route outside 0.0.0.0 0.0.0.0 10.34.249.33 100
route outside 0.0.0.0 0.0.0.0 192.168.6.2 101
route dmz 192.168.168.0 255.255.255.0 192.168.6.2 1
route dmz 192.168.169.0 255.255.255.0 192.168.6.2 1
route dmz 192.168.170.0 255.255.255.0 192.168.6.2 1
telnet timeout 5
ssh timeout 5
console timeout 0
Cryptochecksum:a070fee62a7b83f54f5926ad32f67603
: end
Thanks/Regards
Pawan Harle
Hi Pawan,
Everything looks fine, you would just need the nat statement as well:
nat (dmz) 1 0.0.0.0 0.0.0.0
global (inside) 1 interface
for DMZ users to access serevrs in inside and go to internet as well.
Hope this helps.
Varun
Varun Rao
sir,
     Sir Dmz user have their own gateway to access internet thats y no need through internet via ASA.
  To access server connected to dmz interface i have put below commands.
thanks,
pawan
