Help-need to allow ports 18082 and 18086 inbound (ASA5510)
ceezr1997
Hello everyone, n00b here.
As the title reads, I need help to alow ports 18082 and 18086 inbound to one of my internal servers.
I pretty much now how to create a static nat rule but I dont know how to only allow those two ports.  I dont want to open the server to all ports.
This is what I am doing via ASDM v6.1:
Configuration-NAT Rule-Add=Add Static NAT Rule
Original
Interface: inside
Source: my internal IP address
Translated
Interface: outside
Use IP Address: my available external IP address
Now under PAT I assume that's where I put the ports, so I place a checkbox on Enable and select TCP.  Then I enter 18082 on both the Original and Translated Port boxes.  I tried adding 18086 by entering 18082-18086 or with a comma as a separator but it doesnt allow it and spits an error saying that the format is incorrect.
click [OK]
Now is that how I add a single port to forward to my internal server?  Do need to create another Static NAT Rule including the second port of 18086
Thanks for the help!
Julio Carvajal
Hello Cesar,
Yes, you will need to do it and afterwards you will need to open those ports on the ACL applied to the outside interface (inbound direction).
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Julio Carvajal
Hello Cesar,
Julio
Julio Carvajal
thanks for the reply  jcarvaja.
to clarify - I will have TWO NAT rules under my NAT Rules section, one for each port configured as stated above.
then I will go to my Access Rules and apply those two ports to that outside IP address?
I currently have an access rule with that outside IP address for an old website address no longer being used, it's configured as follows:
Interface: outside
Action: permit
Source: any
Destination: my outside ip address
Service: tcp/htpp <-more on this at the end
Enable Logging - Checked
Logging Level: Default
More Actions:
Enable Rules - Checked
In regards to the service, I can click on the elipsis button [...] - go to add - TCP service group - give it a group name and description and on the bottom box Port/Range enter the needed ports and [Add >>], am I correct?  How can I add two ports on this same service group?  Separate them with a "," or a ";"? ie: 18082,18086  or 18082;18086?
Thank you once again.
Hello Cesar,
That is correct, lets add them and this setup is going to work.
Hope you have a great day,
Julio
Julio Carvajal
it worked, I am good to go!
thank you for your help!!!
