Help on Port Forwarding Cisco ASA
john
Hello All,
we are trying to port forward  exchange (which is working fine)
obj network EXCHANGE
host 172.16.17.14
  nat(inside,outside) static interface service tcp smtp smtp
access-list EXCHANGE_in extended permit tcp any object EXCHANGE eq smtp
access-group EXCHANGE_in in interface outside
but when i add another port forwarding for OWA
obj network OWA
host 172.16.17.14
  nat(inside,outside) static interface service tcp https https
access-list OWA_in extended permit tcp any object OWA eq https
access-group OWA_in in interface outside
i can access OWA, but sending/receiving emails fail.
PLEASE ADVISE.
John
Dennis Mink
I think what is happening is that when you add the second object called OWA, with the same IP as the EXCHANGE object, that is when you break connectivity.
use a single obbject for 172.16.17.14 and call it MAIL for instance static NAT the MAIL object for smtp and https instead of trying it with 2 different objects.
Please rate if helpful
Please remember to rate useful posts, by clicking on the stars below.
