Help setting up FTDv in Azure
Hi all,
We have deployed an FTDv into Azure. We can ping the device and ssh to the device but unable to connect to the FDM via https.
When logging into the the FTD via ssh we see the below prompt:
cisco-tdv:~$
I am not sure how to configure the device from here in order to allow connections from web browser to FDM.
Any assistance would be much appreciated.
Nick
MJHi
Try to login using default admin/Admin123 via ssh and you should get wizard.
Mark Elsen
    - Check logs on the FTDv when trying https , check if anything related comes , if nothing is seen then check below :
 + Ref : https://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/consolidated_ftdv_gsg/ftdv-gsg/m-ftdv-azure-gsg.html#con_7759521
    >...(check items below and or whether executed especially for https) - but read the complete paragraph too
  • Click Allow selected ports to view and choose the inbound ports to be opened for acess by the internet. Choose any of the following ports from the Select Inbound Ports drop-down list. By default, SSH (22) is selected. (take care!!)  (only apparently)
    • SSH (22)
    • SFTunnel (8305)
    • HTTPs (443)
MJHi
That fixed it. Thank you very much
