Showing results forĀ
Search instead forĀ
Did you mean:Ā
Help with ASA 5510 Configuration
Catch22_M
Hi!  I'm having a problem configuring an ASA 5510.  A previous employee started the config and left abruptly.  He established a VPN Tunnel between two of our sites and that's working without an issue.  The problem is, the network behind the 5510 at the remote location cannot access the internet.  I'm new to the ASA and I've spent a LOT of hours looking at this and I'm almost ready to join the previous guy!  I'm sure it's a really simple problem, but I keep over looking it.   Any help would be appreciated, the config is as follows…
ASA Version 8.2(1)
hostname PH-Firewall
domain-name pleasehelpme.com
enable password HXrQty4kqW8s8yeE encrypted
passwd ucA.qrYJWD9UyIFz encrypted
names
name 67.XXX.XX.XX gateway description default gateway
name 39.105.XX.XX pleasehelp_fw description pleasehelp firewall
name 10.100.1.0 pleasehelp_lan description chicago LAN
name 10.50.40.0 tps_lan description tps LAN
interface Ethernet0/0
nameif Public
security-level 0
ip address 67.XXX.XXX.XX 255.255.255.240
interface Ethernet0/1
nameif Internal
security-level 100
ip address 10.50.40.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
domain-name pleasehelp.com
same-security-traffic permit intra-interface
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object ip
protocol-object tcp
access-list pleasehelp_atl extended permit ip pleasehelp_lan 255.255.255.0 tps_lan 255.255.255.0
access-list pleasehelp_atl extended permit ip tps_lan 255.255.255.0 pleasehelp_lan 255.255.255.0
access-list pleasehelp_atl extended permit icmp tps_lan 255.255.255.0 pleasehelp_lan 255.255.255.0
access-list pleasehelp_atl extended permit icmp pleasehelp_lan 255.255.255.0 tps_lan 255.255.255.0
access-list Public_access_in extended permit object-group DM_INLINE_PROTOCOL_1 pleasehelp_lan 255.255.255.0 tps_lan 255.255.255.0
access-list Public_access_in extended permit ip tps_lan 255.255.255.0 any
access-list Public_access_in extended permit icmp any any echo-reply
access-list inside_nat0_outbound extended permit ip any any
access-list Internal_access_in extended permit ip any any
access-list outside_access_out extended permit icmp any any
pager lines 24
logging enable
logging asdm informational
mtu Public 1500
mtu Internal 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat-control
global (Public) 10 interface
global (Internal) 101 interface
nat (Internal) 0 access-list inside_nat0_outbound
nat (Internal) 101 0.0.0.0 0.0.0.0
access-group Public_access_in in interface Public
access-group Internal_access_in in interface Internal
route Public 0.0.0.0 0.0.0.0 tps_gateway 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
aaa authorization command LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http tps_lan 255.255.255.0 Internal
http pleasehelp_fw 255.255.255.255 Public
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set FirstSet esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map pleasehelp_atl 1 match address pleasehelp_atl
crypto map pleasehelp_atl 1 set peer pleasehelp_fw
crypto map pleasehelp_atl 1 set transform-set FirstSet
crypto map pleasehelp_atl interface Public
crypto isakmp enable Public
crypto isakmp enable Internal
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 4320
crypto isakmp policy 5
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 30
telnet timeout 5
ssh pleasehelp_fw 255.255.255.255 Public
ssh tps_lan 255.255.255.0 Internal
ssh 192.168.1.0 255.255.255.0 management
ssh timeout 30
console timeout 0
management-access Internal
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ntp authenticate
ntp server 128.138.140.44 source Public
ntp server 64.90.182.55 source Public
ntp server 96.47.67.105 source Public
ntp server 24.56.178.140 source Public prefer
webvpn
vpn-idle-timeout none
tunnel-group 39.105.0.30 type ipsec-l2l
tunnel-group 39.105.0.30 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
service-policy global_policy global
privilege cmd level 3 mode exec command perfmon
privilege cmd level 3 mode exec command ping
privilege cmd level 3 mode exec command who
privilege cmd level 3 mode exec command logging
privilege cmd level 3 mode exec command failover
privilege show level 3 mode exec command wccp
privilege show level 3 mode exec command dynamic-filter
privilege show level 3 mode exec command webvpn
privilege show level 3 mode exec command module
privilege show level 3 mode exec command uauth
privilege show level 3 mode exec command compression
privilege show level 3 mode configure command interface
privilege show level 3 mode configure command clock
privilege show level 3 mode configure command access-list
privilege show level 3 mode configure command logging
privilege show level 3 mode configure command ip
privilege show level 3 mode configure command failover
privilege show level 5 mode configure command asdm
privilege show level 3 mode configure command arp
privilege show level 3 mode configure command route
privilege show level 3 mode configure command aaa-server
privilege show level 3 mode configure command crypto
privilege show level 3 mode configure command ssh
privilege show level 3 mode configure command dhcpd
privilege show level 5 mode configure command privilege
privilege clear level 3 mode exec command dns-hosts
privilege clear level 3 mode exec command logging
privilege clear level 3 mode exec command arp
privilege clear level 3 mode exec command aaa-server
privilege clear level 3 mode exec command crypto
privilege clear level 3 mode exec command dynamic-filter
privilege cmd level 3 mode configure command failover
privilege clear level 3 mode configure command logging
privilege clear level 3 mode configure command arp
privilege clear level 3 mode configure command crypto
privilege clear level 3 mode configure command aaa-server
prompt hostname context
Cryptochecksum:4d9389e9520e98a2a0f1fa462739c03f
: end
3 Accepted Solutions
Absolutely, do let us know
-Varun
Varun Rao
In order to not break the VPN it would be like this,
no access-list inside_nat0_outbound extended permit ip any any
Then with the changes you previously did with jcarvaja, you should bring your internet up.
Mike
Mike
You need to add this asd well:
Varun
Varun Rao
12 Replies 12
Julio Carvajal
Hello Catch22,
Please remove the  following:
no global (Internal) 101 interface
no global (Public) 10 interface
and add the following:
global (public) 101 interface
With this you should be able to go out, you were missing the proper Nat and Global command,
Please let me know if this works, if not we can create some captures and packet-tracers but I think this is gonna work.
Best Regards,
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Still no dice.  I removed those lines and added the one you suggested, but I'm still unable to get to the internet from those servers.  The ASA hits the internet fine.
Just for testing purpose, can you tell me the ip address of one of the PC's from where you are trying to access internet??
Varun
Varun Rao
If we fix it, we will break your L2L tunnel, look at this statement:
Now look at the ACL
This is saying, Dont do NAT at all, this lines will take precedence on the ones that Jcarvaja gave you. I need to have the following info in order to fix the internet and dont break the VPN:
Source Network for VPN traffic
Destination Network for VPN traffic
Once you have this you can do the following:
That way, it will wont do NAT only if they are going thru the VPN, if not going across the VPN, it will take the lines jcarvaja told you.
Mike
Mike
Absolutely, I agree with Mike. You need to do as he said, and thats y i needed a test pc ip, If you want to verify whether it is this nat statemnet causing the issue (which I am very sure), lets say you are tesing from ip 10.1.1.1, then add an acl:
access-list inside_nat0_outbound line 1 extended deny ip host 10.1.1.1 any
and test teh internet after that from the PC 10.1.1.1 you would see it connecting.
which means yu have a very open acl and you need to first define the VPN traffic and only create an ACL and nat statement specific for that traffic rather than ip any any.
Varun
Varun Rao
Wow!  Thanks for the responses, guys!  I'm going to try this right now....just so I'm clear....
I need to remove these statements....
and add this one...
I'll report back when it's done.  Thanks again!!
-Varun
Varun Rao
Mike
Mike
Still can't hit the internet...here's the revised config with ip info....
ASA Version 8.2(1)
hostname fw-1
names
name 75.61.244.81 pts_gateway description pts default gateway
name 59.51.16.30 pleasehelp_fw description pleasehelp firewall
name 10.100.1.0 pleasehelp_lan description Atlanta LAN
name 10.100.20.0 pts_lan description pts LAN
nameif Public
security-level 0
ip address 75.61.244.84 255.255.255.240
nameif Internal
security-level 100
ip address 10.100.20.1 255.255.255.0
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
management-only
ftp mode passive
protocol-object ip
protocol-object tcp
access-list pleasehelp_atl extended permit ip pleasehelp_lan 255.255.255.0 pts_lan 255.255.255.0
access-list pleasehelp_atl extended permit ip pts_lan 255.255.255.0 pleasehelp_lan 255.255.255.0
access-list pleasehelp_atl extended permit icmp pts_lan 255.255.255.0 pleasehelp_lan 255.255.255.0
access-list pleasehelp_atl extended permit icmp pleasehelp_lan 255.255.255.0 pts_lan 255.255.255.0
access-list Public_access_in extended permit object-group DM_INLINE_PROTOCOL_1 pleasehelp_lan 255.255.255.0 pts_lan 255.255.255.0
access-list Public_access_in extended permit ip pts_lan 255.255.255.0 any
access-list inside_nat0_outbound extended permit tcp pts_lan 255.255.255.0 pleasehelp_lan 255.255.255.0
pager lines 24
logging enable
mtu Public 1500
mtu Internal 1500
mtu management 1500
no failover
arp timeout 14400
nat-control
global (Public) 101 interface
access-group outside_access_out in interface Public
route Public 0.0.0.0 0.0.0.0 pts_gateway 1
http server enable
http pts_lan 255.255.255.0 Internal
encryption 3des
hash sha
group 2
lifetime 4320
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh pts_lan 255.255.255.0 Internal
ssh timeout 30
console timeout 0
ntp authenticate
webvpn
tunnel-group 59.51.16.30 type ipsec-l2l
tunnel-group 59.51.16.30 ipsec-attributes
pre-shared-key *
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
privilege show level 5 mode exec command import
privilege show level 5 mode exec command running-config
privilege show level 3 mode exec command reload
privilege show level 3 mode exec command mode
privilege show level 3 mode exec command firewall
privilege show level 3 mode exec command asp
privilege show level 3 mode exec command cpu
privilege show level 3 mode exec command interface
privilege show level 3 mode exec command clock
privilege show level 3 mode exec command dns-hosts
privilege show level 3 mode exec command access-list
privilege show level 3 mode exec command logging
privilege show level 3 mode exec command vlan
privilege show level 3 mode exec command ip
privilege show level 3 mode exec command ipv6
privilege show level 3 mode exec command failover
privilege show level 3 mode exec command asdm
privilege show level 3 mode exec command arp
privilege show level 3 mode exec command route
privilege show level 3 mode exec command ospf
privilege show level 3 mode exec command aaa-server
privilege show level 3 mode exec command eigrp
privilege show level 3 mode exec command crypto
privilege show level 3 mode exec command vpn-sessiondb
privilege show level 3 mode exec command ssh
privilege show level 3 mode exec command dhcpd
privilege show level 3 mode exec command blocks
Cryptochecksum:6782022c779cdee5e7fff215d54570bc
: end
Varun
Varun Rao
WOOOOO HOOOOO!! That got it! Thanks guys!  I owe you all alcohol!!!  Thanks again!!
No worries
You can mark the thread as answered if everything is resolved and do rate helpful post.
Cheersss
Varun
Varun Rao
