Help with ASA (5520) Basics (ASDM)
dsm600rr
Hello all,
Very new here and to Cisco, so I apologize if this is not the correct spot to post.
So I am a ACSS Certified Avaya Engineer and I am looking to get more into Networking.
I have an older 5520 ASA that I was able to Factory Default and load the default config.
My ASA is running: Cisco Adaptive Security Appliance Software Version 9.1(7)
The Problem I am running into, if I go to: https://192.168.1.1 and install the ASDM Launcer (Cisco ASDM 7.1(3)) - It installs however I never see the program shortcut to run it.
If I navigate to the install folder, I can run it however:
I also cannot get the Java Web Start to work, and I installed the latest Java:
PC is running Windows 10. Any help would be appreciated.
9 Replies 9
Amine ZAKARIA
Hello @dsm600rr ,
Can you provide the output of these commands ?:
show ssl
show run all ssl
show run http
show run asdm
show run aaa
dir
@Amine ZAKARIA
Absolutely:
@dsm600rr ,
Add these commands and test :
asdm image disk0:/asdm-713.bin
aaa authentication http console LOCAL
username EngineerAvaya password You_PASS privilege 15
@Amine ZAKARIA
Appreciate the suggestions. Same issues. I ran the commands and its almost like they dont take. I can still log back in to CLI without the password I set:
@dsm600rr ,
Test the asdm access, the aaa authentication http console LOCAL is used for asdm not CLI.
if ASDM Access did not work, and since it's not a production environment, use  :
logg console 7
logg on
Test the asdm authentication
no logg console 7
no logg on
Share the attached Logs.
dsm600rr
@Amine ZAKARIA
Can you expand a bit? Still very new.
I have my laptop patched into the Management Port and Console Cable in the Condole Port.
"Test the asdm access, the aaa authentication http console LOCAL is used for asdm not CLI." - Not sure what you mean here. How to test?
Here is how I cleared the ASA, thats about as far as I got.
en = privilege mode, short for enable
password = press enter for no password
wr er = write erase to erase the current configuration
confirm by pressing enter
show startup-config = should now show “No Configuration”
reload noconfirm = Reboots ASA
Pre-Configure firewall now thorough interactive prompts: no
conf t = configure terminal
config factory-default = loads the factory default configuration
wr = write memory (saves the configuration)
show startup-config = should now show the new default configuration
@dsm600rr ,
I meant access from ASDM using the user Cisco you have created, access the https://192.168.1.1 download your ASDM install and authenticate.
the aaa authentication http console LOCAL, permitting you to authenticate to ASDM using ASA local users.
Milos_Jovanovic
Hi @dsm600rr,
You are running latest Java, which disables TLS v1.0 and v1.1. On the other hand, your ASA5520 can run only TLS v1.0.
Please see this post.
BR,
Milos
@Amine ZAKARIA
@Milos_Jovanovic
Thank you both for the help!
