Help with Firewall Rule to Allow SNMP To Switch Behind ASA
Matthew Martin
Level 5
Level 5
Hello All,
ASA: ASA5510
Software: Cisco Adaptive Security Appliance Software Version 9.1(6)11
We have recently setup a new location and have it configured behind a Firewall. The Flow would look like:
MPLS <---> ISR4321 Router (*10.28.1.1) <---> ASA5510 (*10.28.1.3) <---> C3650 Switch (*10.28.1.2)
What I would like to be able to do is, allow all traffic coming from a specific Server on the OUTSIDE interface (*Server = 192.168.5.14), to be allowed to talk to the C3650 Switch, which is on the INSIDE.
If I run packet-trace command below (*not sure this is correct or not) I get the following:
# packet-tracer input INSIDE icmp 10.28.1.2 8 0 192.168.5.14 detail
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
Forward Flow based lookup yields rule:
in id=0xad914828, priority=13, domain=capture, deny=false
hits=76618607, user_data=0xaec82a58, cs_id=0x0, l3_type=0x0
src mac=0000.0000.0000, mask=0000.0000.0000
dst mac=0000.0000.0000, mask=0000.0000.0000
input_ifc=INSIDE, output_ifc=any
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in id=0xae17ad28, priority=1, domain=permit, deny=false
hits=41757027, user_data=0x0, cs_id=0x0, l3_type=0x8
dst mac=0000.0000.0000, mask=0100.0000.0000
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 192.168.0.0 255.255.0.0 INSIDE
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in id=0xae17cf48, priority=111, domain=permit, deny=true
hits=18206, user_data=0x0, cs_id=0x0, flags=0x4000, protocol=0
src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0
dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0, dscp=0x0
input_ifc=INSIDE, output_ifc=INSIDE
Result:
input-interface: INSIDE
input-status: up
input-line-status: up
output-interface: INSIDE
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
So Given that output above, does that mean the default DENY ALL rule is preventing me from doing what I want?
If so, could someone suggest a rule that would allow traffic to that Switch from that specific Server address?
Any thoughts or suggestions would be greatly appreciated.
Thanks in Advance,
Matt
Aditya Ganjoo
Please enable same-security-traffic permit intra-interface on the ASA and then test.
Aditya
Please rate helpful posts and mark correct answers.
Hi Aditya, thanks for the reply.
I inserted that command as you suggested. Now, the pings still don't go through, but the packet-tracer command says they SHOULD be allowed.
If I setup a capture I can see the following:
CISCOASA# show cap
capture ipam-in type raw-data interface INSIDE [Capturing - 290 bytes]
  match ip host 192.168.5.14 host 10.28.1.2
capture in-ipam type raw-data interface INSIDE [Capturing - 290 bytes]
  match ip host 10.28.1.2 host 192.168.5.14
CISCOASA#
CISCOASA#
CISCOASA# show cap ipam-in
5 packets captured
1: 11:06:52.465430 10.28.1.2 > 192.168.5.14: icmp: echo request
2: 11:17:44.143013 10.28.1.2 > 192.168.5.14: icmp: echo request
3: 11:18:20.118798 10.28.1.2 > 192.168.5.14: icmp: echo request
4: 11:23:39.046475 10.28.1.2 > 192.168.5.14: icmp: echo request
5: 11:23:46.146614 10.28.1.2 > 192.168.5.14: icmp: echo request
5 packets shown
CISCOASA#
CISCOASA# show cap in-ipam
5 packets captured
1: 11:06:52.465445 10.28.1.2 > 192.168.5.14: icmp: echo request
2: 11:17:44.143028 10.28.1.2 > 192.168.5.14: icmp: echo request
3: 11:18:20.118814 10.28.1.2 > 192.168.5.14: icmp: echo request
5 packets shown
So does this mean the return pings are being sent, but they are just not reaching me?
Thanks again for the reply.
Matt
Hi Matt,
Yes you are correct.
Probably we are missing a return route to the ASA.
Aditya
