Help with port forwarding ASA5505 v8.2
paul.awad
Having an issue doing a port translation on an ASA5505 for RDP.
I have a /29 allocated by ISP and when I port forward the address assigned to the outside interface RDP works perfectly, however when I try to use another IP within the /29 range, I get nothing.
I am only new to ASA so please forgive if this is something obvious...
Relevant config is:
interface Vlan1
nameif inside
security-level 100
ip address 10.1.12.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address X.X.X.217 255.255.255.248
access-list OUTSIDE-IN extended permit tcp any host X.X.X.218 eq 3389
static (inside,outside) X.X.X.218 10.1.12.10 netmask 255.255.255.255 sh run acces
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-group OUTSIDE-IN in interface outside
When I used the outside IP address and it worked perfectly, config difference was only
access-list OUTSIDE-IN extended permit tcp any host X.X.X.217 eq 3389
static (inside,outside) tcp X.X.X.217 3389 10.1.12.10 3389 netmask 255.255.255.255
Any help would be greatly appreciated
11 Replies 11
Jouni Forss
The only 2 reasons that come to mind fast is that you either
Have this configuration enabled
sysopt noproxyarp outside
In which case insert this command
no sysopt noproxyarp outside
OR
The ISP has done something wrong on their end
So can you first check "show run sysopt" and share the output with us
- Jouni
Thanks Jouni for the quick response...
Wish that were the answer... a sh run sysopt gives nothing... I added the no sysopt command and still no joy.
I had thought about calling the ISP however this ASA is a replacement of an PIX which I only just put into place. Under the PIX, that IP address responded.
Do you know what else could be causing this...?
Well you can check the ASA configurations fast with the "packet-tracer" command
packet-tracer intput outside tcp 1.2.3.4 12345 x.x.x.218 3389
This would simulate a connection coming from behind "outside" interface from source address 1.2.3.4 with source port 12345 to your Static NAT IP address of the server.
This should tells us if the ASA configuration are fine for the most part.
If you have a host outside your network that can be used to test connectivity I would check if the ACL rule gets any hits
Also when testing configurations and frequently changing NAT configurations I would suggest using "clear xlate local " to clear any possible old NAT translations active on the firewall (they may remain even if the commands have been removed)
You can also use "show xlate | inc " to check the active translations for your host
- Jouni
Jouni,
OK..., packet tracer output shows allow on all points which is confusing
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
After the packet tracer there was 1 match on my outside access list... cleared the counters and tried to connect via an external IP... and 0 matches!!!
Have also cleared the xlate and still nothing...
Yes, the "packet-tracer" command generates hitcounts on the ACLs when used.
There shouldnt really be many possibilities why this would not work.
If indeed you have not disabled Proxy ARP on the "outside" (which seemed to be ok) and have cleared Xlates and allowed the traffic and the "packet-tracer" goes through then I cant see any other reasons other than the ISP.
Wonder if doing Trace Route from a Internet host towards both the ASA interface IP address and this extra IP used for the Static NAT would show up differently. This could perhaps provide some information if the ISP has indeed messed up something.
- Jouni
Hi Jouni,
Traceroute follows the same path up until the interface IP address and does not go any further, although I am not allowing ping/traceroute to the other IP addresses, only the outside interface IP...
Seems like it is routed to the right place from ISP point of view.
Any other suggestions? Really appreciate your help and quick repsonses on this.
Just to be sure, would it be possible to see your ASAs whole configuration (with masked public IP addresses ofcourse)
To be able to go through them.
You can also use traffic capture on the ASA itself to confirm if ANY traffic is coming towards the extra public IP address
access-list CAPTURE permit ip any host x.x.x.218
access-list CAPTURE permit ip host x.x.x.218 any
capture CAPTURE type raw-data access-list CAPTURE interface outside buffer 1000000
Then test from the Internet and use the commands
show capture
and
show capture CAPTURE
To see if any traffic reaches your ASA. If not I cant think of anything else at the moment than ISP configurations or some device infront of the ASA causing problems.
- Jouni
Hey Jouni,
Packet capture gave me this output which didnt have any TCP 3389... but had some random UDP ports only?
   1: 21:54:55.108377 802.1Q vlan#2 P0 X.X.X.218.63420 > 208.67.222.222.53:  udp 44
   2: 21:54:58.751929 802.1Q vlan#2 P0 X.X.X.218.63420 > 208.67.220.220.53:  udp 44
   3: 21:54:59.492238 802.1Q vlan#2 P0 X.X.X.218.63976 > 208.67.222.222.53:  udp 45
   4: 21:55:02.807468 802.1Q vlan#2 P0 X.X.X.218.63207 > 216.239.34.10.53:  udp 55
   5: 21:55:02.807651 802.1Q vlan#2 P0 X.X.X.218.63976 > 208.67.220.220.53:  udp 45
   6: 21:55:06.863495 802.1Q vlan#2 P0 X.X.X.218.63414 > 199.253.183.183.53:  udp 56
   7: 21:55:24.599563 802.1Q vlan#2 P0 X.X.X.218.65039 > 208.67.222.222.53:  udp 42
Config is below:
ASA Version 8.2(5)
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 3
interface Ethernet0/2
description TO LAN
interface Ethernet0/3
description TO LAN
interface Ethernet0/4
description TO LAN
interface Ethernet0/5
description TO LAN
interface Ethernet0/6
description TO LAN
interface Ethernet0/7
description TO LAN
interface Vlan1
description TO LAN
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Vlan3
shutdown
no forward interface Vlan2
nameif backup
security-level 0
ip address X.X.X.42 255.255.255.252
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group icmp-type ICMP
description ICMP types permitted
icmp-object echo
icmp-object echo-reply
icmp-object unreachable
icmp-object time-exceeded
access-list OUTSIDE-IN remark TRAFFIC PERMITTED TO ENTER THE OUTSIDE INTERFACE
access-list OUTSIDE-IN extended permit icmp any interface outside object-group ICMP
access-list INSIDE-IN remark INSIDE ACCESS
access-list INSIDE-IN extended permit tcp any any
access-list INSIDE-IN extended permit ip any any
access-list INSIDE-IN extended permit icmp any any
access-list BACKUP-IN remark TRAFFIC PERMITTED TO ENTER THE BACKUP INTERFACE
access-list BACKUP-IN extended permit icmp any interface backup object-group ICMP
pager lines 24
logging enable
logging buffered debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu backup 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (backup) 1 interface
nat (inside) 0 access-list NO-NAT
access-group INSIDE-IN in interface inside
access-group BACKUP-IN in interface backup
route outside 0.0.0.0 0.0.0.0 X.X.X.222 1 track 1
route backup 0.0.0.0 0.0.0.0 X.X.X.41 254
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sla monitor 1
type echo protocol ipIcmpEcho X.X.X.X interface outside
num-packets 3
frequency 10
sla monitor schedule 1 life forever start-time now
track 1 rtr 1 reachability
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
So we are only seeing the host using the Static NAT IP address is trying to do DNS querys but receives no reply.
I would still bet that some device in front of the ASA is causing this or the ISP has configured something wrong.
Sometimes when replacing the firewall it might be possible that the ISP still has an old ARP table marking for the IP address (Public IP -> PIX MAC address).
If the setting is at its default it would mean that it would take 4 hours to clear and after that update with the MAC of the new ASA (instead of the PIX MAC) Naturally you could test this with the PIX if it indeed had this Static NAT also.
Then again the interface IP address is functioning ok so I am not sure about that. The way a device might update the upsteam devices ARP is Gratuitous ARP. I am not sure if ASA does this.
- Jouni
Hi Jouni,
Still the same... I am going to give up on this for the time being as I cant be bothered trying to explain this to customer service at the ISP... will end up wasting more time. I have forwarded all RDP to the interface IP and all works there so there is no need at this point to continue. Whn in fact I need another IP from the /29, will chase up the ISP then...
Thanks very much for your help.
Ok,
Shame we couldnt get this to work.
Unless there is somekind of misstype/typo in the IP addresses then I dont know what the problem could have been on your side.
Maybe if you get this solved at some point with the ISP you could let us know that the problem was if it indeed was on the ISP side.
- Jouni
