09-02-2011 04:12 AM - edited 03-11-2019 02:20 PM
Please take look of topology attached herewith.
I want to deny this below Lan IP address of Manewada Router to accessing Server connected to L3 switch.
Source Destination Action
172.16.1.0 172.16.99.0 Deny
172.16.2.0 172.16.90.0 Deny
172.16.3.0 172.16.90.0 Deny
172.16.4.0 172.16.90.0 Deny
172.16.99.0 172.16.1.0 Permit
172.16.99.0 172.16.3.0 Permit
172.16.99.0 172.16.4.0 Permit
Any Any Permit
I did the below configuration, but this is blocking two way traffic ...
Please help me to solve this issue.
hostname ASA
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address 172.16.222.2 255.255.255.0
interface Ethernet1
nameif inside
security-level 100
ip address 172.16.111.2 255.255.255.0
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
access-list branch-ctrl extended permit ip 172.16.99.0 255.255.255.0 any
access-list branch-ctrl extended deny icmp 172.16.1.0 255.255.255.0 172.16.99.0 255.255.255.0
access-list branch-ctrl extended deny icmp 172.16.2.0 255.255.255.0 172.16.99.0 255.255.255.0
access-list branch-ctrl extended deny icmp 172.16.3.0 255.255.255.0 172.16.99.0 255.255.255.0
access-list branch-ctrl extended permit ip any any
pager lines 24
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
access-group branch-ctrl in interface outside
router ospf 1
network 172.16.111.0 255.255.255.0 area 0
network 172.16.222.0 255.255.255.0 area 0
log-adj-changes
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:f1cb9b8578dc3e36f453a9cd616db34a
: end
Solved! Go to Solution.
09-02-2011 06:21 AM
Hi Pawan,
Your ACL should look like this:
You also need to add this configuration:
inspect icmp
This will meet all of your requirements. Inbound ICMP traffic from the remote networks will be denied, but your internal servers will still be able to send ICMP traffic to the remote networks. The ICMP inspection will dynamically allow the return traffic through the ACL, only when your internal servers initiate the request.
Hope that helps.
-Mike
09-02-2011 06:21 AM
Hi Pawan,
inspect icmp
Hope that helps.
-Mike
09-02-2011 09:35 PM
Hi Mr.Mike
Thanks for the help. It has been done sucessfully by using your suggestion.
Pawan
