How do you monitor temperature on FTD device?
ABaker94985
Our FTD and FMC are both running 6.6.1. How do you 1) look at temperature on the FTD either through FMC or CLI? and 2) Does anyone know the SNMP OID for the temperature? Thanks
bcoverstone
If anyone finds out, that would be fantastic. It looks like monitoring these FTD devices is all but impossible.
You can query FMC via the CIMC since it is built on a UCS C220 server.
For Firepower chassis, there are also show commands:
https://www.cisco.com/c/en/us/td/docs/security/firepower/fxos/fxos221/cli-guide/b_CLI_ConfigGuide_FXOS_221/introduction_to_the_firepower_security_appliance.html
You should be able to get to them via REST API as well. I found a reference in LogicMonitor's documentation that indicates they do this:
https://www.logicmonitor.com/support/monitoring/networking-firewalls/cisco-firepower-chassis-manager-monitoring
Looking at a Firepower 4110 just now using
 https://<fcm_IP>/api/sys/chassis/chassis-env
 ... I was able to retrieve the temperature:
<snip>
"inletTemp"
: "21.000000", "lastUpdatetime": "2021-09-06T10:51:36.177",
<snip>
tabularasa138
Is this not the OID for Temp on these things?
entSensorValue - 1.3.6.1.4.1.9.9.91.1.1.1.1.4
