How to block url for HTTPS traffic without SSL decpryptions on FTD 6.2.3?
slv_slv
Frequent Visitor
Frequent Visitor
Hi All
I'm using FTD on ASA 5506x v6.2.3.16-59 (managed by Firepower Device Management) with latest updates.
I have rule with app filter HTTPS and url category which should be blocked Dating (just for testing)
as you can expect this rule is not working correclty - thats why I'm asking you for help here 😉
Traffic hit correct sec rule, so app detection is working fine, also url categoryzation seems to be fine.
Why this traffic is allowed?  Whats wrong here ?
I wouldn't do a SSL decrypt becase my device is too small, but based on SSL cert SNI block urls.
Slawek
balaji.bandi
you need to bring up the rule above the 2nd rule, as per the screenshot, your 2nd rule has any any HTTPS allowed.
here is a guide :
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/1332-how-to-purchase-and-setup-web-filter-licensing-on-the-rv340.html
BB
balaji.bandi
here is a guide :
BB
For me, it looks like it worked as expected and the session was blocked.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
@karsten
Where do you see action block on provided screenshots? This webpage is fully loaded on my laptop.
The top of your screenshot says "Connection Event ---- Block".
Did you clear your browser cache or try opening the site in a private/incognito browser session?
