How to configure syslog facility code in FTD 1xxx series by FDM
a118123
I searched for it and it seems that only FTD under FMC supports configuring facility code of remote syslog server.
Any idea to do so? Thanks.
This second post I think about syslog in frp 1k and I think you select answer using API.
a118123
I checked API explorer reference but it seems that there is no similar parameter of facility code.
https://developer.cisco.com/docs/ftd-api-reference/latest/#!addsyslogserver
Marvin Rhoads
FDM is limited to basic management features. To do what you are asking, FMC is required.
