12-21-2019 02:38 PM
Hello everybody,
This is a test case where there is a Cisco ASA 5585-X (SFP+ ) connected to catalyst 6500-E (10G X2 XFP) using a 10G link.
How to monitor the reciveing optical power at ASA.
12-21-2019 03:09 PM
check the command :
show interface g0/1 transceiver detail (replace g0/1 with your interface number).
12-23-2019 09:35 PM
12-24-2019 03:58 AM - edited 12-24-2019 04:00 AM
Appologies, i have just looked in the ASA5585 - i do not see this options. ( running code -Version 9.6(4)14)
# show interface tenGigabitEthernet 0/6 ?
detail Detailed interface information
ip IP configuration
stats Interface statistics
summary Interface summary
| Output modifiers
<cr>
here is further information can be find :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuv91578/?rfs=iqvred
01-05-2020 02:49 AM
Hi Sir,
Thanks for your reply, But is there any solution using which i can monitor the Optical Receive power in Cisco ASA Devices.
01-05-2020 06:18 AM
No you cannot do this. The ASA software does not have this feature.
