Implmenting SG300 Layer 3 Switch for InterVLAN Routing with ASA 5505
meGunnett
IMAGE: ASA Before SG300
My current setup has an ASA 5505 acting as my main gateway, firewall, and router for network. The ASA with its 100 MB bandwidth is a bottleneck for my network. Everything is working now though there are obvious speed issues. So I purchased an SG300-10 Layer 3 switch it hopes that it could take over the Inter VLAN routing. ASA 5505 – I have configured multiple interfaces to allow my VLANs to be routed properly. I also have DHCP relay set up for VLANS 2-5 to go to the DHCP/DNS Servers 192.168.0.13 & 192.192.168.0.200
IMAGE DHCP Server
New Setup
IMAGE: ASA 5505 & SG300
For my new setup, I have deleted the VLAN interfaces off the ASA5505 and moved them to the SG300 and setup DHCP Relay It seems that SG300 is having issues routing to the VLAN1 Inside network as well as the internet. DHCP relay does not seem to be working since I implemented the SG300.
Devices on VLAN1, can access the internet and on VLAN1 but none of the other VLAN’s.
Devices on VLAN 3, cannot access the internet, but can access access other VLAN’s such as VLAN 2 & VLAN 4.
ASA Configuration Before Making Any Changes
ASA Configuration After Adding SG300
SG300 Config
SG300 IP Routes
SG300 ARP Table
Any help would be much appreciated!
kcrane2
What is the default GW for devices on VLAN1?  I suspect it's the ASA from the behavior you describe.
You really need to setup a point-to-point vlan for the ASA to the SG-300.   Something like this
VLAN1 <------> SG-300 <------> VLAN 900 <-----> ASA
VLAN2 <-------------|
VLAN3 <-------------|
VLAN4 <-------------|
All clients on the inside should point to the SG-300 VLAN IP as their default gateway.  The SG300 then points to the ASA's IP on VLAN 900 as its default gateway.  The ASA is told that 192.168.X.X is routed to the SG-300's IP on VLAN 900.  The ASA's default GW points to your internet device.  This keeps the ASA from having a layer 2 connection to some of its inside clients and layer 3 to others.
What you have now can be made to work but would result in asynchronous routing which will cause you headaches at some point.
You are correct about the ASA being set as the default gateway on VLAN 1.
I will experiment with making a transit VLAN like VLAN 900.
