Showing results forĀ
Search instead forĀ
Did you mean:Ā
Interface not displaying logs
sgalloway
Level 3
Level 3
I have a deny acl configured on my Inside Interface with Debug logging enabled and when l view the logging console within the ASDM set to debugging l do not see any entries for  this acl ??
It is recieving hits on the acl but does not show any entries in the log ??
Interface Inside
ACL
172.16.4.189 any http deny debugging
Device is a Cisco ASA 5520 , ASDM 6.2(1) and ASA Version 8.2(1)
Any assistance would be greatly appreciated
15 Replies 15
Thanks for the output, that explains why it is not showing you.
You have the following command to disable syslog# 106100 which is what you are after:
no logging message 106100
To reenable logging of syslog# 106100:
Secondly, your ASDM is only configured with "warnings" (level 4) syslog, while your access-list log is logged under "informational" (level 6), that's why it's not showing up as well. Please modify the logging level for your ASDM to level 6 (informational) as follows:
logging asdm informational
Hope that helps.
