Internal routing issue (asa 5510 v 8.2.2)
GEOFFREY BARKER
Hello again,
Well, I seem to be getting 'schooled" by these ASA 5510 devices lately.   I just had a lot of help resolving an inter-interface communications problem and now I've got a (hopefully small) routing problem on another 5510.  I hope the community can help me again.
I have a problem with implementing a route statement on an ASA 5510.
The 5510 has 1 inside and one outside interface.  The FW is the default GW for the subnet on the inside interface (192.168.1.1).  However, for traffic bound to 192.168.100.x, I need it to route back out onto the inside subnet and send it to another ASA5510 (192.168.1.3).
I've setup a route statement (route inside HQ-inside 255.255.255.0 192.168.1.3 1) but it is not working.
I imagined that since I'm not sending the traffic 'through' the firewall, I wouldn't need to deal with access lists and nat.  Am I wrong on that?
I've done a packet trace and it looks like the packets are dropping at the nat rule (nat (inside) 2 0.0.0.0 0.0.0.0.0).  I wonder if I need to do something similar in the last problem.  Something like a NAT Exemption) but I'm still not fully aware of what I'm doing... (embarassed to say).  Sorry to ask you to spoon feed me like this.
As always really appreciate any help.
Geoffrey
Here's my current Conf (edited for security):
Result of the command: "show running-config"
hostname NorthASA
domain-name domain.org
enable password c7Ik4QWNoVuUmbYX encrypted
passwd c7Ik4QWNoVuUmbYX encrypted
names
name 192.168.100.0 HQ-Inside
name 192.168.1.254 NHFDServer2-Inside
name xxxx NHFDServer2-Outside
interface Ethernet0/0
speed 100
duplex full
nameif outside
security-level 0
ip address xxxx 255.255.255.248
interface Ethernet0/1
speed 100
duplex full
nameif inside
security-level 100
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
management-only
boot system disk0:/asa822-k8.bin
ftp mode passive
clock timezone PST -8
clock summer-time PDT recurring
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service RDP tcp
port-object eq 3389
object-group service DM_INLINE_TCP_0 tcp
group-object RDP
port-object eq www
port-object eq https
port-object eq smtp
access-list valley_nat0 extended permit ip 10.99.9.0 255.255.255.0 172.29.12.0 255.255.255.0
access-list valley_cryptomap extended permit ip 10.99.9.0 255.255.255.0 172.29.12.0 255.255.255.0
access-list Inside_nat_static extended permit ip host NHFDServer2-Inside any
access-list Outside_access_in extended permit tcp any host NHFDServer2-Outside object-group DM_INLINE_TCP_0
access-list inside_nat_static extended permit ip host NHFDServer2-Inside any
access-list inside_nat_outbound extended permit ip 192.168.1.0 255.255.255.0 172.29.12.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
global (outside) 1 10.99.9.1-10.99.9.200 netmask 255.255.255.0
global (outside) 2 interface
global (outside) 3 NHFDServer2-Outside netmask 255.255.255.255
nat (inside) 1 access-list inside_nat_outbound
static (inside,outside) 10.99.9.201 192.168.1.31 netmask 255.255.255.255
static (inside,outside) 10.99.9.202 192.168.1.32 netmask 255.255.255.255
static (inside,outside) NHFDServer2-Outside NHFDServer2-Inside netmask 255.255.255.255
access-group Outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 74.92.226.62 1
route inside HQ-Inside 255.255.255.0 192.168.1.3 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TEST esp-aes-256 esp-sha-hmac
crypto ipsec transform-set VALLEY esp-aes-256 esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map valley_map 1 match address valley_nat0
crypto map valley_map 1 set pfs group5
crypto map valley_map 1 set peer 146.129.253.3
crypto map valley_map 1 set transform-set VALLEY
crypto map valley_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption aes-256
hash sha
group 5
lifetime 86400
crypto isakmp ipsec-over-tcp port 10000
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 30
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username admin password ra.2Iw6nrBEaHn0M encrypted privilege 15
tunnel-group 146.129.253.3 type ipsec-l2l
tunnel-group 146.129.253.3 ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:d7f1b5a56370f3a2e2a6afe3c497ff8d
: end
17 Replies 17
I mean that, sorry I am not checking the diagrams anymore hehe
Yes, as you add more work to the ASA>>>>
Glad I could help man
Have a good one
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello Geoff,
The diagram you just set it's what I am saying dude jaja
Ok ...why ICMP works?
     Because ICMP is stateless for the ASA unless you add the following command and becomes statefull
          Fixup Protocol ICMP
I ensure you that as soon as you add the highlated command the ICMP will stop working
Why any other traffic fails.. I would say tcp traffic? Because it is stateful
Again back to my theory
How to solve it:
TCP state bypass
access-list test permit tcp 192.168.1.0 255.255.255.0 192.168.100.0 255.255.255.0
class-map test
match access-list test
class test
set connection advanced-options tcp-state-bypass
Clear local-host
Then give it a try and Keep me posted dude
Remember to rate all the helpful posts
Julio Carvajal
Well, I had high hopes for TCP Bypass but it doesn't appear to be a usable solution.  At least not yet.
First, just FYI,  It seems to be necessary on both ASAs.  If I deactivate the Service Policy on either FW, communications fail.
Worse, although some communication is occuring,  Most is failing.
For example, I can map a drive across the connection but cannot browse the content.  I can make an RDP connection but mouse and keyboard information does not seem to make it accross the connection.  Telneting to the remote FW (from either direction) fails outright.
So, unless, there's some way to improve the performance, I can't call it a working solution at this time.
Note that the connection between HQ and Highline locations is a dedicated fiber connection running at 100Mbps and this is the only traffic running across it.  So, I can at least say it's not a bandwidth issue.
Any ideas about how to proceed?
Geoffrey
