issue in Converting FCM into FDM
Hi folks,
I am getting issue in accessing my Firepower 4120 via FDM, earlier it was opening with the same, but now it is opening with FCM.
Please anyone suggests how can i convert this FCM into FDM, so that can access with FDM.
Thanks!!!
Marvin Rhoads
There should be two ip addresses configured. One is the chassis management and that uses the GE MGMT port on the device. FCM will appear as the web UI there on https and fxos cli via ssh. The other address is assigned to the FTD logical device on the configured management interface (one of the network module physical interfaces). You can see it under the interfaces tab in FCM (and the address appears in the logical devices tab).
