LANT-to-LAN using port NAT...
kelleywilliams
I have a 3000 series Concentrator with two public interfaces. On one public interface, I have a LAN-to-LAN using static NAT to a Cisco IOS IPSec router...
I would like to establish a LAN-to-LAN with the external (public) interface to the same IOS IPSec router...(no problem)
I would like to NAT the external interface to the same translated network...
It would look something like this:
NAT LAN-to-LAN rule:
Interface Source Net.: Translated --------------------> Remote Network
2 public 10.1.x.x : 191.1.1.1 --------------------> 172.x.x.x
3 external 10.2.x.x : 191.1.1.1 ----------------------> 172.x.x.x
IPSec LAN-to-LAN
Ethernet 2 pub 10.1.x.x peers 172.x.x.x
Ethernet 3 ext 10.2.x.x peers 172.x.x.x
Can I use port NAT for the above NAT scenario?
I would like to NAT the two public addresses to the same "translated network".
Thanks...
kelleywilliams
Well, I guess I have to answer my own question...
The Cisco VPNC does not allow more than one LAN-to-LAN connection to the same PEER...
The port NAT rule would work just fine if the VPNC could have more then one LAN-to-LAN to the same PEER...
