Logging Problem with Pix 506
atattan123
I have an old pix 506, it was disconnected for some time and now I feel I want to use it. But I forget the password, I can ping from the port to my pc but I can not ping from pc to the pix.
Any idea how to reset the password or erease it or back to the default factory setting .
Patrick Iseli
Level 7
Level 7
See this document:
Password Recovery and AAA Configuration Recovery Procedure for the PIX
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_password_recovery09186a008009478b.shtml
Factory reset after password recovery:
write erase
reload
sincerely
Patrick
sachinraja
Level 9
Level 9
Hello
do you remember the IOS version running on the PIX. If yes, please see the URL below to reset the PIX password.
Hope this helps.. all the best..
Raj
Patrick Iseli
Level 7
Level 7
See this document:
write erase
reload
sincerely
Patrick
