major problems with 5.1(1) release
mhellman
Level 7
Level 7
I've spend many hours over the last week working on intermittant sensing interface failures on our IPS sensors (models 4235,4240,4250,4255) after an upgrade to 5.1-1a. I even rebuild 6 sensors from scratch using an 5.1-1a ISO image, and 5 out of the 6 have failed. I believe there is something seriously wrong with version 5.1(1). Cisco doesn't seem all that interested in troubleshooting and simpy told me to rebuild my sensors as 5.0 (I have 3 data centers and 20 sensors).
Another fine example of Cisco's fine software development and QA. If I seem bitter, it's only because I am;-)
Avoid this upgrade.
d.zagorski
I've also had issues with 5.1-1. Fortunately, I only upgraded 5 of our 16 4255's. Tried everything to work around the issues, but ended up reverting back to a 5.0-2 image, which must be done onsite via console port on the 4255. Only then was I able to update to 5.0-5 and latest sigs. Don't think I'll try a version upgrade again without testing it on a single sensor for a week or so. Cisco still has no fix for this yet. Live and learn.
I have sucessfully re-imaged x2 IPS4255s locally. Then upgraded my IDS/Sec Mon v2.1 to IPS MC 2.2 and Sec Mon 2.2 since doing this I can no longer push signatures out. The IPS MC produces the following message:
The Sensor reports its V version as V1.0 but the MC reports V version.
I have tried to re-import and even deleted a sensor of the IPS MC, I can no longer get it back in!
So something is certainly up with the software.
PS. receiver.exe has started to hog the CPU now as well.
