Management Port routing issue on ASA5525x
jpeterson6
Level 2
Level 2
I've got a client with a Management Port set up for Out-of-Band management. Here's the configuration of the interface and some relevant static routes:
interface Management0/0
description MGT
speed 100
duplex full
nameif Mgt
security-level 100
ip address 10.38.100.20 255.255.255.0 standby 10.38.100.21
management-only
route inside 10.0.0.0 255.0.0.0 10.38.103.1
route Mgt 10.48.0.0 255.255.0.0 10.38.100.254
The route through Mgt interface is required as my client accesses the device from a subnet that isn't local to M0/0.
Unfortunately, now any traffic originating from outside and destined to 10.48.0.0/16 is choosing the Mgt interface. I had thought that the 'management-only' keyword prevents this from happening (traffic traversing between interfaces).
There is a broad scope of /16 addresses on the 'inside' so just swapping destinations won't work (the client wants to avoid a routing table with 50+ static entries, understandably)
My temporary solution was to do this:
route inside 10.0.0.0 255.128.0.0 10.38.103.1
route inside 10.128.0.0 255.128.0.0 10.38.103.1
route Mgt 10.0.0.0 255.0.0.0 10.38.100.254
What would be the best setup in this situation?
If 'management-only' doesn't prevent traffic from using the Mgt interface, what is the point of the command?
Michal Garcarz
You are absolutely right about "managent-only" command. It does not allow for transit traffic (routing).
I have it in my lab. Tested in both directions:
1. When received traffic from any other interface and destination was thru management-only interface
%ASA-4-418001: Through-the-device packet to/from management-only network is denied: icmp src inside:2.2.2.10 dst outside:3.3.3.3 (type 8, code 0)
2. When received traffic from management-only interface and destination was thru any other interface:
%ASA-4-418001: Through-the-device packet to/from management-only network is denied: icmp src outside:1.1.1.10 dst inside:3.3.3.3 (type 8, code 0)
So - it works as expected. That interface should never route packets.
Are you sure it's working as you described ? DId you capture traffic ? Did you verify that in logs, nat and conn tables ?
If yes you might hit a bug. What version of ASA do you use ?
Michal
Sorry for the late response. I got tied up with some other clients and was quite busy for awhile.
I am getting the denied packets as you specified. The issue is the fact that it's even trying to use the Management Interface to begin with in its routing decisions.
I think it was probably just a misunderstanding on my part. I had thought that the keyword 'management-only' would remove the option to use it as a destination interface for routing decisions.
